Old 10-04-2017, 09:43 AM   #1
DVD player
In our 2017 26DBH, we have the furrion DVD player, which has standard video output but no hdmi. Our LG flatscreen does not have the yellow video connector therefore we have no color picture, is there a way to fix this?
LuxeCamper72 is offline   Reply With Quote
Old 10-04-2017, 09:51 AM   #2
rsdata's Avatar
when you say standard video output... what is the color of the plug(s) on the back of the player?
do you have the exact model nmuber of the DVD player?
2014 Shamrock 183
Old 10-04-2017, 09:54 AM   #3
It may be shared with the component input on your tv, look closely at the component inputs and see.
Glampster67 is offline   Reply With Quote
Old 10-04-2017, 10:05 AM   #4
rsdata the plugs are Red White and yellow on the wall unit that came with the camper, the tv doesn’t have a standard red white and yellow jack
Old 10-04-2017, 10:20 AM   #5
So your tv doesn't even have the red and white for audio? If it does then the green for component is used for the yellow input for video.
Old 10-04-2017, 10:22 AM   #6
Ok thank you Glampster67, I’ll try this tonight
Old 10-04-2017, 10:31 AM   #7
Iwannacamp's Avatar
If you select the wrong HMDI source it will show up in B/W...
2017 Puma 297RLSS
Old 10-04-2017, 10:37 AM   #8
rsdata's Avatar
I think your only option is to replace the Furrion DVD player, OR just buy a cheap separate DVD player with HDMI output, (which I think they all have these days) and use it to play your DVD's. There is NO adapter that will take Yellow plug out and change to HDMI input.
2014 Shamrock 183
Old 10-04-2017, 11:21 AM   #9
K2Kevin's Avatar
I have seen many new TV's that no longer have the composite/RCA jacks on them and only have HDMI inputs.
If this is the issue (sounds like it from original post), you can get an RCA to HDMI converter box. I think they require power, but should do the trick. They don't cost much ($15).
Update: This one looks to be powered from USB port. https://www.amazon.com/dp/B01MD0XHO0?psc=1
BTW: I have one in reverse. OLD TV (No HDMI) and used HDMI to RCA. Works good, image is no longer Digital HDMI, but still nice option.
Since we're on the subject. I would like to share what I have found works great for me. The TV I choose was a "Smart TV". The main reason was it has a USB input. I convert some DVDs, or download videos and use conversion software to format the video for use with the TV (MPEG4). Put about 40 videos on a small USB stick, and you have a nice selection for the kids or yourself. Great for those rainy days and streaming is not an option.
K2Kevin is offline   Reply With Quote
Old 10-04-2017, 11:34 AM   #10
K2Kevin's Avatar
Not exactly...
Component is Red, Green, and Blue, all used for video (RGB), and would still have a Red/White for audio, or the use of digital audio (Fiber optic).
I guess a photo or model of the TV in question would help a lot.
Old 10-04-2017, 12:09 PM   #11
Yea, make sure you have the specified red and white for audio, not the red that is part of the red green blue for component, and then look to see if the green is shared for just video.
Old 10-04-2017, 12:28 PM   #12
K2Kevin's Avatar
It's funny. When the OP is missing just one detail, how it can send us in circles trying to help. Does sound like it has Component since it was mentioned the get "no color", so they get picture but its black and white?
Old 10-06-2017, 07:51 AM   #13
Got an update for us? The suspense is killing us!
Old 10-06-2017, 08:00 AM   #14
Dan_M's Avatar
Our DVD player only had composite output and TV only has component and HDMI.
I purchased an open box DVD player from Best Buy with an HDMI output for 35 bucks.
2017 Prime Time Avenger ATI 27DBS
2016 Chevy Silverado 2500HD Gas
'17: 42
'18: 25
Dan_M is offline   Reply With Quote
Old 10-06-2017, 09:15 AM   #15
rsdata's Avatar
This is you BEST option...
2014 Shamrock 183
Old 10-06-2017, 09:26 AM   #16
Islander's Avatar
Not sure....
...But would something like this be of any help ?
See Link > HERE
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 10-06-2017, 09:36 AM   #17
Dan_M's Avatar
Originally Posted by Islander View Post
Not sure....
See Link > HERE
Islander
This will not work.
You need a convert analog to digital.
https://www.monoprice.com/product?p_id=9994
'17: 42
'18: 25
Old 10-06-2017, 09:43 AM   #18
Dan_M's Avatar
For that price you should look into an open box DVD player with HDMI.
Composite video isn't the greatest quality. Converting composite to HDMI will look like poo.
'17: 42
'18: 25
Old 10-06-2017, 09:55 AM   #19
Yes! We are up at Kohler Andreas, and the yellow plugged into the Green on the tv and it’s a great picture! Thank you all!
Old 10-06-2017, 10:14 AM   #20
The best a DVD player can put out is 480i unless it up samples and it really isn't actually any better...why would composite video really make it any worse since that is the max resolution of composite video?
babock is offline   Reply With Quote
dvd
