Emergency Window in Bedroom
We have a rear bedroom with an emergency window. I was afraid to open it, ever. We had a fantastic fan installed to provide extra ventilation. But that wasn't enough. My husband has opened the window and stuck a piece of wood in it to prop it open. We didn't have a screen so that isn't an option for me. He put screen mesh over the window, but it didn't provide enough of a seal for my liking. This past week, we finally came up with a solution, while camping. We took the screws out of most of the frame (top and sides) and slid screen mesh between the frame and wall. We sliced the screen at the sides just above where the levers would reach when opening the window and allowed extra mesh for the bottom, clipping to make the corners fit. We put adhesive velcro from the side slits down the sides and bottom of the frame and firmly pressed it into both the frame and then made sure the screen was tight and added another piece of velcro around the corners. Everything stayed tight and secure. I only had to loosen the bottom portion to close the window and then secured the screen back along the bottom. Works great.
