04-17-2019, 06:10 PM
Fresh water drain
Hi folks !
Another newby question.
I have a 2019 Grey Wolf 26DJSE.
I found my fresh water drain, and connected an extension with a ball valve so I can drain the tank without having to crawl under the camper. While I was connecting the extension, I noticed another hose leading off at a 90 degree angle on the drain. Is this where the pump is pulling water from the tank, or is it the overflow? I did notice that there is a small hole with a screen over it along side the fresh water input port on the side of my camper. Just need some expert clarification so I know exactly how this thing works.
04-17-2019, 06:29 PM
Originally Posted by PinTwister
Hi folks !
Can you post a picture?
04-17-2019, 07:15 PM
Reply to Mr. Dan
It is dark now. Will post it later. Might be a while because rain starts tonight and will continue for about 4 days. The connection in question is a simple T conection. leaving the bottom of the tank, 1 side is the drain and the other side has a white hose connected to it. It runs between the tank and the frame, then disappears into never-never land.
04-17-2019, 09:34 PM
Yes, this is where the water pump draw's fresh water from your fresh tank.
04-17-2019, 09:40 PM
something like this ??
04-18-2019, 12:03 AM
Originally Posted by TheWolfPaq82
I hope that didn't come from the factory like that! Would be the first thing I modified. Remove that valve and put the cap on the tee. Accident waiting to happen.
04-18-2019, 07:18 AM
T connection
That is the exact fitting I have on mine. Only I put a 90 degree 1/2 inch barb on mine and ran a hose to the side of my trailer. Thanks for the confirmation that the other hose is the pump intake. I still need to know if the small hole with the screen next to the fill port is the vent, and does it also double as an overflow.
04-18-2019, 08:01 AM
I was digging in mine yesterday, and I found that what looks like the vent was not connected to anything, and had a blob of hot glue on the back side of that vent to seal it.
The overflow is at the top of the fresh water tank itself, and I think it just runs over the side of the tank.
04-18-2019, 08:06 AM
overflow
That doesn't sound right. That would leave a way for dirt to get into the system.
04-18-2019, 08:13 AM
There very well may be a screen at the overflow, I haven’t looked under there to see it, but I know on mine, there isn’t a line run from the vent port next to the fill tube. You can easily see this by taking off the lower panel inside the vanity door. This is where your water pump is located, so you will need to get in there for winterizing and dewinterizing anyhow.
04-18-2019, 08:22 AM
Don't get it. There's a ball valve with an extension and cap attached. What's the point?
04-18-2019, 09:19 AM
On my 16BHS Pup there is a plastic 90 fitting coming out the side of the fresh water tank that acts as an overflow. I too have the little screen by the water port but not sure what it is for. Just fill your tank up all the way and your bound to find where the overflow is
Thomas & Jessica
2016 Cherokee Wolf Pup 16BHS
2018 GMC Canyon, 4-door long bed, 3.6 v6, tow package
04-18-2019, 09:38 AM
My mod. cap leaked horribly. Over 2 feet of clearance between the cap at the bottom and the ground.
Should get a pick of the bar I made that fits onto the ball valve. Don't have to crawl under the trailer to open valve. Cap is only on when traveling or sitting in the driveway.
04-18-2019, 09:40 AM
cap keeps crud out of the line and keeps little critters from building nest in the end of the tube. Mud Wasps ?? yeah I've had few plug things up.
04-18-2019, 09:53 AM
In what way?
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-18-2019, 10:12 AM
Originally Posted by Herk7769
In what way?
All it takes is a piece of tire or other debris hitting that thing and taking it all off including breaking the tank. If you want a ball valve, put a tee in and run a line sideways with a ball valve close to the edge of the trailer. If the cap is leaking, you need a better cap. All I have is a cap and it never leaks.
04-18-2019, 10:53 AM
Its a PEX drop and not part of the tank, it would bend out of the way.
In my camper if my ball valves get hit I have bigger problems because my entire sewer system would be wiped out.
04-18-2019, 10:59 AM
Not one piece of PEX in that picture that was posted in post #5. If it was PEX, it would be a different story
04-18-2019, 11:05 AM
vent
AEOMT: You are correct about the small screened vent hole.
I looked inside my vanity for the connections and I found a large corrugated hose and another one for shore water hookup. There was also the small hole in question, and it is actually a "dummy" port that goes nowhere.
04-18-2019, 11:10 AM
Overflow
Judging from what I have heard on this thread, the overflow is a simple back flow through the fill tube.
Please correct me if you have definitive knowledge as to where the EXACT place the overflow emanates from.
