Old 08-30-2020, 12:10 AM   #1
Fridge/Freezer Latch Problems
2020 16FQ with Furrion 10 cu ft 12V fridge/freezer.
After getting to our destination on a recent trip we found that the freezer door opens too easily (the contents had fallen out onto the floor) and the fridge door was very difficult to open (had to push up on the door while trying to open). I had to remove the fridge latch so my wife could open it.
The strange thing is that we didn't have this problem before so I think it is something to do with the flexing of the fridge or the frame it is in or maybe a leveling issue.
I checked the manual and there does not appear to be any adjustments that can be made, strange.
Two month wait to get it in to be looked at, which is too long to wait.
Instead I've fixed it with a 3D printed part. Part cost is $0.21, design time was 30 minutes, print time was one hour. Now the screws in the latch receiver have slots allowing me to adjust the receiver up or down as needed.
Maybe there is a better way to fix it but for me this was quick and easy to do.
The STL file is attached. I had to go through some hoops to get around the dumb configuration of this forum. To access:
- remove .txt extension
- unzip to get .stl
AndyA is offline   Reply With Quote
Old 08-30-2020, 07:19 AM   #2
SeaDog's Avatar
Boy talk about a double dumb problem both the frig and the forum with that said you got your problems solved so you are good to go.
Retired Navy
2016 Flagstaff 26 FKWS
Old 08-31-2020, 12:23 AM   #3
JSP
Exact same camper.. exact same fridge.. exact same problem. I wonder how many cooling problems are caused by poor hinge/latch/bad seals on these things?
JSP is offline   Reply With Quote
Old 08-31-2020, 12:46 AM   #4
PM me your name and address and I will mail you one of these printed parts.
I haven't had any cooling problems fortunately - the back wall frosts over.
Andy
Old 08-31-2020, 09:06 AM   #5
Exact same fridge, exact opposite... fridge side is loose and freezer tough to open. Need to learn how to 3D print.
Charliebrn is offline   Reply With Quote
Old 08-31-2020, 11:00 AM   #6
2021 model - 1st trip ~120mi - no issues. 2 trip ~380 miles no issues. 3rd trip - 1st leg 218mi no issues, 2nd leg montross va to virginia beach - 130 miles, freezer door opened spilling ice cream & melted onto floor. On way home , 271 mi - same issue. From 3rd trip on, I have installed WDH so possibly the single axle trailer is bouncing more. 4 trip on way to Cape Cod from NJ, fuel stop check at CT, once again freezer door opened and spilled the ice cream again.
My observation is that if the freezer(and ref) door compartment has heavy item(s) and of course if there is ice cream in the freezer they would likely to open from all the bouncing around.
I am trying to see if a normal fridge child proof lock would work.
21wolfpupfq is offline   Reply With Quote
Old 08-31-2020, 11:10 AM   #7
Charliebrn and 21wolfpupfq - PM me your name and address and I will mail you one of these printed parts.
Old 08-31-2020, 08:48 PM   #8
My latch in my 24js is sticking too after I had it back at the dealer because the fridge wont turn on. I would like a latch too. I'll pay for it.
brianmarion is offline   Reply With Quote
Old 09-03-2020, 05:08 PM   #9
If Furrion can't make a simple fridge latch that works then it's a good thing they are not trying to make more complex products like A/C units. Oh...
I have five of these printed parts left. If you have this fridge and this problem PM me your name and address. I will update here when they are gone.
Andy
Old 09-09-2020, 03:13 PM   #10
Jello, I just recieved the updated latch you printed. Thank u so much! I really appreciate it!
Old 10-05-2020, 04:48 PM   #11
AndyA: A shout out to you for your improved latch receiver. It is excellent!
For others: I received AndyA's improved latch today, and after installing it my first impression is that it works superbly. In addition to being able to adjust the latch receiver up and down AndyA lengthened the bevel at the top and the bottom, increasing the the allowable tolerance between the fridge and freezer doors. I put some down force on the fridge door to simulate weight of items in the door, and it still latches. The final test will be the next time I go camping, but I have confidence that this fixes the problem. This design is a major improvement over the one distributed with the unit.
SteveSVT is offline   Reply With Quote
Old 10-10-2020, 06:29 PM   #12
PDuB-IA2MI's Avatar
Another reason for FR to take out Furrion refers and go with Cannon, which has a travel lock standard.
TT: Wolf Pup 16BHS-Black Label
TV: 2020 Traverse V92 Tow Package
WDH: Equal-i-zer 600/6000
Brake Controller: Curt Echo
PDuB-IA2MI is offline   Reply With Quote
Old 10-21-2020, 09:00 PM   #13
- unzip to get .stl
Hello AndyA
I read your fix on the furrion fridge latch, I to have the same fridge and same problem. I noticed if I lift the bottom door a bit the latch works like it should, I think the door has sagged down but no way to adjust it up, I was just going to add another nylon washer in bottom hinge. I like your idea, I would appreciate the part you made also if possible, I will pay you for the part.
Thank you
Brett, Hoover dam mechanic.
Dam mech is offline   Reply With Quote
Old 10-29-2020, 06:07 PM   #14
All of the parts from the first batch have now gone. This was much more popular than I expected! To continue this I have created a posting in the classified section.
Andy
Old 05-17-2021, 12:34 PM   #15
Andy
Thanks so much! I have a 16FQ (2021) with the same problem. How do I PM you? Sorry... I'm very low tech!
Elisa P
Shredder J is offline   Reply With Quote
Old 05-17-2021, 12:47 PM   #16
bikendan's Avatar
Elisa P
You were sent a Welcome Letter from FRF when you joined the Forum. Click on the Inbox link on the top green bar to read it. It will have information for you there.
Here is the link to the Forums 101 page. It will explain how to use the Forum:
https://www.forestriverforums.com/fo...sics-6778.html
Old 05-17-2021, 01:20 PM   #17
Yes, I still have these available as long as my classifieds listing is up. Send me a PM for details.
Shredder - I have your PM. Andy
Old 06-24-2021, 01:50 AM   #18
Latch
I would like to purchase this latch how can I buy it.
phreak is offline   Reply With Quote
Old 06-24-2021, 01:58 AM   #19
Hi Andy can I buy this latch from you. Let me know all the info you need.
Old 06-24-2021, 11:52 AM   #20
PM sent.
fridge
