Old 10-05-2014, 07:38 PM   #1
GSlone
Grey Wolf 28WP Battery Question
I will admit, I'm a newbe, only out a few times. But each time I've gone out I've had issues with the battery almost drained. The first time I didn't have the breakers off but the second time I turned off all the breakers and when I went back out to the trailer a few weeks later the propane gas alarm was chirping and the battery was almost drained - with all the breakers off. So, each time I park the trailer after a trip do most of you disconnect the battery?
Gary & Kelly
2016 Chev. 2500 HD
2014 Cherokee Wolf Pac 28WP
2009 Harley Davidson Street Glide
GSlone is offline   Reply With Quote
Old 10-05-2014, 07:43 PM   #2
davel1971's Avatar
yes, you will have too, or it will for sure be dead in a week or 2. Mines stays plugged into house
David & Lynn
Old 10-05-2014, 07:44 PM   #3
davel1971's Avatar
oh, and turning off breakers makes no difference. The drains are on the 12 volt circuits. Propane detector, radio clock, etc.
David & Lynn
Old 10-05-2014, 08:15 PM   #4
GSlone
Thanks for the confirmation, putting a battery disconnect switch on it should stop that problem then.
Gary & Kelly
2016 Chev. 2500 HD
Old 10-06-2014, 05:27 AM   #5
davel1971's Avatar
sure will. If not going to be used for very long periods of time, a trickle charger isn't a bad idea either. I'm talking for more than a few months
David & Lynn
battery, grey wolf
