Old 12-07-2022, 10:02 PM   #1
Grey Wolf Anode needed
I have a 2013 17' Grey Wolf. Mostly sits in storage. I just winterized it (I see mice eating the styrofoam near the water heater shutoff are @#$%^&.
Anyway the anode is about 50% worn out but I want a spare. I'm not sure what material it is, would it be aluminum or magnesium?
Is Amazon an OK place to buy one (or Walmart online)?
Thanks so much!
RCSP is offline   Reply With Quote
Old 12-07-2022, 11:12 PM   #2
Magnesium will produce a sulfur smell if the water contains bacteria. Aluminum-Zinc won't produce the gas that gives the sulfur smell. Yes, Walmart Online or Amazon is just fine for getting anode rods. If you don't have any concerns about sulfur smell, it is believed that magnesium gives you better corrosion protection.
NavyLCDR is offline   Reply With Quote
Old 12-07-2022, 11:50 PM   #3
wmtire's Avatar
Thanks so much!
All Suburban water heaters will come with a magnesium anode from the factory. The optional aluminum anode rod is to be used if the magnesium one is consumed too fast due to hard water conditions. This doesn't sound like your case, so the magnesium is what you will want to keep using.
Please see this video provided by Suburban Manufacturing to our forums. We keep 5 different informational videos in the FAQ section you may find of benefit at the following link:
https://www.forestriverforums.com/fo...es-135977.html
Here is the one about the anode rod(s)
2011 Flagstaff 831 RLBSS
Old 12-08-2022, 07:47 PM   #4
Thanks! Great info
anode, grey wolf
