Originally Posted by Squilliam
Thanks, I figured they were 12v I was just having some difficulty with my multimeter. I was replacing my tweeters when I realized the wiring for the little LED’s on the stock ones are fairly high gauge. I’ll be able to wire everything to a secondary controller and run 12v light fixtures in the rig without running any wires I hope.
You will be good.
My Alpha Wolf has 12 gauge wiring for the 12v accessories. (even if it had 18ga. the LED lights use very little current on 12v and will be fine)
I swapped out my LEDs with a RGB (color changing) LED system from Amazon that cost $9 and some waterproof LED strips. It has remote and makes it very easy to change colors, brightness, pattern... Both on the outside under the awning and inside around the popout and countertop.
