Old 10-24-2019, 06:30 AM   #1
New Thermostat
So I have the Dometic thermostat in my 19 Alpha Wolf and it is just too sensitive to everything. Looking for an upgrade. see attached picture
Recommendations? Limited wall space
ChrisMoore is offline   Reply With Quote
Old 10-24-2019, 06:59 AM   #2
I would check behind the front cover to see how many wires you have coming into the unit. If it's only three, you won't really be able to replace it with a home style controller as the 'main' controller is up by your A/C unit at the ceiling. I have a Dometic Brisk with the same thermostat and I thought I could upgrade it.. nope.
montelovers is offline   Reply With Quote
Old 10-24-2019, 07:42 AM   #3
TowPro's Avatar
to sensitive means it cycles on and off all the time? or the temp swing between on and off is too much?
I read from factory it has a 2 deg temp swing. (most homes are set to 1 deg) you can set the temperature differential from the front buttons.
see Temperature Differential page 9
Here is manual
But it appears this thermostat has 3 wires. 12V positive and negative, plus 1 communication wire that goes to AC. than your heater is also wired to AC where the AC controls heater based in input from thermostat. so your not going to replace it with a common home thermo.
2019 Forest River Forester MBS 2401R
TowPro is online now   Reply With Quote
Old 10-24-2019, 02:02 PM   #4
Sensitive. I mean the buttons are sensitive. Keeps kicking over to Celsius, Just a pain to deal with
Old 10-24-2019, 02:09 PM   #5
Got the same T-stat. Had to learn the "Right Touch" to control it. I do like the temp sensitivity, but yeah, the buttons are touchy.
TheWolfPaq82 is offline   Reply With Quote
thermostat
