I called the dealer and they are putting us on the "list". They said that forest river has to approve the repairs before any work can be done. I know this process will probably take awhile so I went ahead and removed the trim board at the bottom of the slide and checked it for sags. The board itself was straight. I put a 7ft level across the floor where it rubs and it does have a small bow in the floor. This is where the floor was giving while stepping on it. I can take my hand and push down here and I can see the floor deflect so it is either bowed or a screw is not fastened. I ended up raising the center of the trim board and this helped until the dealer can fix the flooring issue and my vinyl and trim will at least not get destroyed.
I have purchased 2 new forest river products this year a 2318G that I traded for my Wolf Pup 17JGBL. The thing that I noticed with both is that the quality control doesn't exist at Forest River. I know it is hard to find help today but does no one take pride in their workmanship today. I noticed small things like sawdust and metal shavings that was not cleaned when holes were drilled and caulking that was terrible or missing around the tub area. With all that said and venting over
, I am very pleased with the layout and look of the new Wolf Pup
