08-23-2021, 12:42 PM
Outdoor fridge door opens while in transit
What are you doing to keep your fridge door closed for the duration? We typically have drinks in ours and they don't stay put and the door is open when we arrive.
I'd love to see two magnetic pads (assuming the door is magnetic) joined together by a 6" long strap. One pad on the side of the fridge and one on the door until you get to your destination.
My other thought was to find a thick piece of foam that I could stick to the fridge door and it would be compressed by the camper door when closed.
Open to suggestions. Thanks!
08-23-2021, 12:49 PM
I have heard others use command hooks with a small strap or bunji cord. One on door face and one on the side.
Marc in sunny California
2013 Crusader 260 RLD
2012 RAM 2500 Laramie CTD and 4:10
08-23-2021, 02:05 PM
Yeah, that could work.
08-23-2021, 02:36 PM
2020 Flagstaff Micro Lite 25BRDS SOLD!
2024 Brinkley Z3100
2021 Ford F-350 XLT 6.7L Power Stroke
08-23-2021, 02:51 PM
I use a rubber door stopper under the door. It comes in handy also when airing it out when not plugged in. I had one lying around.
2021 Coachman Northern Spirit 2963BH
2017 Dodge Ram 1500 Laramie
Old:
2019 Rockwood ROO 233S, 1998 Dutchman 747SL, 1988 Jayco 1006, 2001 Skyline Nomad 3710BH,1997 Coachman Catalina lite 249 QB, 2001 Palomino Mustang SC
08-23-2021, 04:08 PM
LOL, as do I! Perhaps I will see if the spacing is right to use it!! I re-anchored mine as close to the outer surface as I felt comfortable doing. I was going to borrow some clay from my kids to get an idea of how much gap there really is between the doors.
The child safety latches would probably be the most secure and no chance of losing anything. Was hoping to find just that, but magnetic instead.
08-24-2021, 06:22 AM
Mopar Guy
i use to use a piece of pool noodle between fridge door and cabinet door.
Dave
2019 Grey Wolf 24JS- sold
1998 Holiday Rambler Imperial 41wds
08-24-2021, 06:45 AM
I am using a tie down strap from an old trailer cover around the middle of the fridge.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
08-24-2021, 07:28 AM
This is what I do too.
An added caution - I've made the mistake of having my outside frig door open when plugging in my camper at home (in preparation for an upcoming trip). The result was my poor little dorm-style frig trying to cool down a 20 x 40 uninsulated building in 90 degree heat. Needless to say, it was running nonstop. When I found it 3 days later, the frig was hot - I mean really hot - on all outside surfaces. Could it have gotten hot enough to cause a fire?? Not sure, but I also don't really want to find out.
So, now my approach is to turn the frig off (turn internal temp setting to off) when I unload it after a trip. That way it won't be running until I want it to (and after I can make sure the door is closed).
Pete
Brian, Stacy, and the kids
2011 F-250 CCSB 6.7L PSD 4WD
2013 Palomino Solaire 269BHDSK
ProPride Hitch
08-24-2021, 11:38 AM
Outdoor Fridge
We have a two door fridge which I secure by sticking a cutting board with magnets across the doors. Works like a charm. I've also seen people use the child safety stick-on latches with good success.
08-24-2021, 11:40 AM
Maybe our refrigerator is different, but you push the door closed (hard) until it clicks, and its locked in place until you pull it to open it.
08-24-2021, 11:58 AM
I replaced the fridge in my outside kitchen with a freezer. Keep the door closed with a childproof "lock".
Second season and nothing spilled after numerous Forest Service roads.
08-24-2021, 12:54 PM
Open door
Try 1” Velcro strips top and bottom, it’ll stay closed. I used it on outdoor fridge on our deck to keep raccoons at bay, it works
08-24-2021, 01:51 PM
It sure would be nice to have a beer fridge made to hold bottles and cans that is about half the size we have, then have an ice maker in there! That would be a great package. But we don't find ourselves needing freezer space much.
Velcro could work. Stick a pad on the body and one on the door with another strip to bridge the to while in transit... Cheap and easy.
08-24-2021, 02:35 PM
I mounted one of these on the metal shelf edge at the bottom of the fridge. Up keeps the door securely closed during travel. I use a small carabiner to keep the latch’s position secure.
https://www.amazon.com/dp/B08CRH62H4...ing=UTF8&psc=1
2015 RAM 3500 Cummins LB 4x4
2018 Rockwood Signature Ultra Lite 8328BS
08-24-2021, 04:48 PM
Bungee cord around fridge. Of course with all the bouncing around you really need to open door slowly to catch what is “going” to fall out when you arrive at your destination.
08-24-2021, 05:29 PM
rfifer
I use velcro wrapped around the side of our garage freezer to ensure the door remains tightly closed. The same thing would work for the outside fridge. A word of caution, however. I learned that velcro is not velcro is not velcro. In other words, there are different strength of adhesion and also velcro connectivity. There is an industrial strength velcro that works very well. That is what I would recommend to be sure that 1) the backside adhesion sticks well and 2) the hook in loop does not come apart from anything heavy (i.e., liquid) inside the fridge when going around a curve.
Bob and Jan
Miami
Grey Wolf 26 DBH
TV F-150
08-24-2021, 06:26 PM
This has served us well for over 18000 miles and they are
1.00 at (guess where),
THE DOLLAR STORE.
We just place it to the right side of the fridge by the wall and then wrap it around to the back, close the door on it and never a problem.
However you still need to open the door slowly as things inside are still free to move. Our fix for that is to use small boxes for sodas and beers and the like. Its much easier to open the door and hold back a box than to try to hold back 10 15 loose sodas or beers
Great suggestion.
That’s what I use on mine. Also use on my residential frig freezer inside so when you close the frig door the freezer doesn’t pop open unknowingly. I wanna say we got gorilla brand hook and loop worked great so far 4 years later.
08-25-2021, 03:33 PM
