With little research, you will find that using the largest wire gauge and shortest length possible is ALWAYS recommended for high power use.
Use sealed batteries near the inverter. Put the inverter close to the batteries.
Thinner wire over any distance results in line loss, lessening the voltage, and the loss is caused by resistance that results in heat generation (hot or burnt insulation, possible fire, or the wire may melt acting like a fuse).
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
