10-30-2021, 08:18 PM
RV newguy
We got a good deal on a seldom used 2019 Forest River Cherokee Wolf Pup 18TO, after the steep initial learning curve we’ve had it out a total of 18 nights, we like it more every time. There's not a winterization kit on it which is just a T off the water pump, a hose and a cap for using the water pump to pull antifreeze out of it's gallon jug and into the water supply lines. Does this mean we don't need to winterize it, or does it mean I need to have additional plumbing put on it so I can winterize it?
We live in the Atlanta Georgia Area.
Thanks fellow campers, it's nice to have this community!
10-30-2021, 08:32 PM
Originally Posted by Keath Bordeaux
We got a good deal on a little used 18TO, had it out a total of 18 nights, we like it more every time. There's not a winterization kit on it which is just a T off the water pump, a hose and a cap for using the water pump to pull antifreeze out of it's gallon jug and into the lines. Does this mean I don't need to winterize it, or does it mean I need to have additional plumbing put on it so I can winterize it?
Hi and Welcome to FRF.
Since you're asking for model-specific information, it helps if you posted year and make since many FR divisions use the same model numbers.
Just because it doesn't come with a winterizing kit, doesn't mean you don't have to winterize. Many entry level trailers don't come with one.
Also, you may not need to winterize, depending on where you live. But you didn't identity where you live in your profile.
10-30-2021, 08:34 PM
Winterizing
Thanks for the quick reply. We live in Atlanta nd it's a Forest River 18TO, built in 2019.
10-30-2021, 08:43 PM
What division of FR built it?
10-30-2021, 08:47 PM
Forest River Wolf Pup 18TO
Cherokee
10-30-2021, 08:53 PM
Also, you may not need to winterize, depending on where you live….
Tucker, GA.
10-31-2021, 12:38 PM
A couple gallons of antifreeze and the time to run it into your water lines is well worth it if there is any chance at all that you’ll get any weather in the upper 20’s/low 30’s. If your coach has that T on the water line by the pump it is really easy.
Or if you have an air compressor you can buy a “blow out” fitting. That process is really easy and there’s no need to run all the antifreeze it of you water lines in the spring.
10-31-2021, 12:44 PM
Don't forget to drain and bypass your water heater.
David, Sherry and our three fur kids, Nicholas, Finnegan and Bentley
2013 Coachmen Encounter 36BH
2014 Honda CR-V/ Blue Ox Patriot II
11-01-2021, 09:36 AM
My 2020 Wolf Pup did not come with a winterizing kit on the water pump either. I bought a Camco RV Winterizing kit form Walmart (approx $14). Installation is pretty simple assuming accessibility to the water pump is reasonably easy. My pump is in a compartment under the sink.
11-01-2021, 10:27 AM
We've got a 2021 18TO, and there are low point drains tucked up underneath on the slide out side. I didn't see them last year until I was almost done winterizing. They are a foot or 2 back from out door shower. Ours is black label version and a year or 2 newer, so perhaps not on yours. I'm in the blow out the lines and no pink stuff except in drains "camp". That's a whole nuther big discussion here LOL. I also forgot first year to remove filter bowl on water pump, luckily it didn't crack but this year I unscrewed and dumped it. Edit to add I'm in northern Michigan so a bit colder than GA!
“I am much inclined to live from my rucksack and let my trousers fray as they like.”
— Herman Hesse
