05-10-2021, 08:13 PM
#21
Trailer Park Supervisor
Originally Posted by skipatroller
Isn't that an oxymoron, low crime are in New Jersey ??
I live in a pretty country area of NJ (believe it or not, there are!). Far enough from urban areas that you don't get the spill off predators, and spread out enough even the local junkies are not an issue (there's ALWAYS local junkies now). I'm not in a 'neighborhood'. When I first bought the house, I used to buy Halloween candy. Don't bother anymore without a single trick or treater in 20 years.
Yes, I drink the water!
05-10-2021, 08:25 PM
#22
We had one stolen off a pop-up while having breakfast in an iHOP. Since then they have all been secured with a snake lock and a locking lug nut.
05-12-2021, 07:27 AM
#23
Originally Posted by Larry-NC
Just wondering how you knew the replacement was from a Toyota.
It said Toyota on the rim itself, so that's what I presumed. The lug pattern looked the same but the holes were much larger (the trailer lugs might fit all the way through. It's still perplexing that they mounted it. Why not just take the tire and be done with it? Whatever. Water under the bridge.
05-12-2021, 07:36 AM
#24
Originally Posted by Bogieboy
it would appear that your local tractor supply shows a compatible wheel and tire in stock if your trailer is a 5 lug wheel: https://www.tractorsupply.com/tsc/pr...el-st205-75d15 if you set your store to bristow VA (pulled from your about me part of your forum profile) it shows available for pickup today...
I really wanted a galvanized rim. I was going to settle for the white painted rims, but TSC website lies. When you add either tires available, it only had ship to store as an option. I called the store to verify. He went even went to see if he could find one. Nonetheless, I have time before the next trip to get locks and a new spare.
05-12-2021, 08:46 AM
#25
That is just insane! I am definitely getting a wheel lock set , and some sort of chain lock. I am also going to look for some sort of locking battery case.
05-12-2021, 08:12 PM
#26
Just remember before you spend what can be a lot of money on countermeasures. All can be defeated. Today's portable power tools with angle grinders and cut off wheels go through a lot of stuff like a knife through butter. You can end up spending more than the batteries are worth for one of those big battery box locks. Most of these thefts do not happen when you stop somewhere to pick up a few groceries or eat on the road. They happen in storage areas away from prying eyes.
05-13-2021, 09:02 AM
#27
Lesson learned?
Yes, it seems that the lesson to be learned is "Do not use unenclosed storage facilities."
Larry
05-13-2021, 09:11 AM
#28
Sometimes I curse my big property, especially cutting 2 acres of grass. But then I'm thankful I have the room to park my trailer right in the driveway.
05-13-2021, 09:32 AM
#29
I'm right there with you... 32 acres and room for a couple hundred R/Vs but thankful I don't have to put mine elsewhere.
05-13-2021, 09:33 AM
#30
Small farm tractor...
Small farm tractor with 6' wide mower, right?
Larry
05-13-2021, 09:39 AM
#31
I wish. John Deere garden tractor GT235(bigger than a typical lawn tractor) with a 42" mulching deck. Six blades under there, hardly leaves a clipping to be seen. The nice thing about it, I mount a giant 44" snow thrower to it, so machine sees year round use, but only one machine to maintain.
05-13-2021, 09:55 AM
#32
What you need
Here's the mower.
Here's a better one, costs a little more.
And the tractor.
Larry
05-13-2021, 10:43 AM
#33
Now THAT'S a tractor!
05-13-2021, 11:33 AM
#34
The right size for that mower
It's the right size for that mower and your field--get your job done in less than half the time.
But a REAL tractor costs $150,000-200,000, has air conditioning, Wi-Fi, GPS, 4-channel audio, and can be programmed to do the entire field by itself. Even the seat would make motorhome owners covetous.
Larry
