Originally Posted by ragribben
We have a 2019 274VFK. We are about to tint the windows and clean the screens.
I am assuming, by the looks of it, I have to unscrew the frame to get to the screen?
Any tips or tricks on doing this? I don't want to mess up anything or break a window!!
We bought the nano Ceramic film to go on the windows and I'm more worried about getting the dang screens out than doing the tinting!! We have 6 windows with screens of which 4 are very large!!
Thanks!
After seeing the picture, your screens look exactly how mine are when I tinted my RV windows last year. I tinted 17 windows of varying sizes, some with screens and some without. You should not have a problem as long as you're careful.
You'll first have to remove outer frame screws, then you'll be able to pull out the screen spline, and finally the screen itself. Before I unscrewed and removed the inside window frame, I secured the outside of the window frame to my RV sidewalls with several pieces of duct tape to ensure the outer frame and window would not fall out. I didn't have another helper holding the window in place from the outside.
I highly recommend going to Lowes or Home Depot and purchasing a roll of window screening, a roll of spline and a spline tool to install it in the tracking. Take a piece of the spline with you so you get the correct diameter. You'll likely tear a screen or two in the process of re-installing the original screen in the window after tinting. I also had spline pieces that were torn up pretty bad because the inside frame screws went into and thru it to hold the window frame in place. Throw the damaged spline away and replace with new.
Lemme know if I can help out with any questions.
