Old 08-21-2020, 10:33 PM   #1
Trailer Dropped - Need Advice
Hi everyone,
We recently purchased our first trailer, a Cherokee WolfPup 17JG. The trailer has had numerous issues and was in the shop. On the way to pick up the trailer the dealer called us to notify us they dropped the trailer while towing it. The trailer was being towed by a forklift when it fell off and proceeded to run into the forklift. The tongue is unusable and the forklift punched a hole in the front of the trailer. The trailer is only 35 days old.
The dealer said they will give us a new tongue and replace the hole. My concern is what latent issues or hidden damage may be possible. Has anyone experienced issues after dropping their trailer? Should we get a lawyer? Thanks in advance.
Overlander_Trailing is offline   Reply With Quote
Old 08-21-2020, 10:46 PM   #2
If it were me, I'd start by talking about my concerns with them face to face to see if I had confidence that they'd fix it properly or not before I got anyone else involved.
Skip12 is offline   Reply With Quote
Old 08-21-2020, 10:54 PM   #3
rsdata's Avatar
forklift running too fast, hit a bump, trailer popped off ball and rolled into the fork punching a hole and bending the tongue in the process.
Your biggest problem is going to be the speed of the repairs... probably not going to be real quick.
Old tongue cut off, new tongue welded on... pretty simple, but the battery box and propane tanks will have to move to the new tongue. All of the trailer wiring should be ok.
Now fix the hole... pretty easy fiberglass patch and gel coat... what else was "forked" on the inside and damaged?
I would want to see the damage BEFORE they start work on it, and take pictures. Then let them work on it and do a good inspection of the damaged areas when it is finished. Crawl under the front where the tongue was welded on, check the welds and paint job. Check interior where fork penetrated. If you are satisfied with the fix then how are they going to compensate you for their error and your loss of time? A free dinner on them?
If your not satisfied then call a lawyer.
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
rsdata is online now   Reply With Quote
Old 08-21-2020, 11:35 PM   #4
NMWildcat's Avatar
Honestly, if it was me with a 35 day old trailer damaged that bad, I'd tell them to keep it and make me a spectacular deal on another unit.
I would not accept a patch to the hole (replace the entire panel), and I would want an extended warranty paid for by them, if you decide to keep it.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 08-21-2020, 11:53 PM   #5
Do you have insurance on that trailer? If so, get your insurance company involved. They can give you a better assessment of the damage. I'd be concerned about hidden damage.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 08-22-2020, 06:08 AM   #6
ETC
I would have them replace the entire unit. Insurance claim I would think it's going to total out this trailer.
ETC is offline   Reply With Quote
Old 08-22-2020, 06:24 AM   #7
Mr Brian's Avatar
Get them to tell you how great the repairs will be. Then make it clear how fortunate it was that no one was hurt. Then say that again, before echoing back to them how great their repairs will be - and that how they *as a dealer* will have no trouble selling it. Then make it clear, but matter of fact, that you have an appointment with a lawyer.
And you should speak with an attorney before signing any document or taking possession of the trailer. Be polite, be firm. Don’t hesitate to look their executive leadership squarely in the eye and clearly state how fortunate it was that no one was injured - or killed.
They may have the trailer, but the ball is in your court.
Brian
2020 Forest River Forester 3011 DSF
Mr Brian is offline   Reply With Quote
Old 08-22-2020, 06:48 AM   #8
tugboat369's Avatar
My concern would be the trailer tung most trailers that is part of the frame and the frames are made on a Jig as to be aligned exactly lined up. so if welding a new one on is not done exactly right the trailer will not tow right.
Camping from 2008, Life member Good Sam / KOA / iRV2
2014 Columbus 320RS
2011 Ford, F250, 6.7D, SRW
tugboat369 is offline   Reply With Quote
Old 08-22-2020, 07:05 AM   #9
Did you ever have it off the lot? If not you are not obligated to take this trailer.
Just like a car. it is not yours until you drive it off the dealers lot.
Good luck.
Lukegsdaddy is offline   Reply With Quote
Old 08-22-2020, 09:54 AM   #10
You got some good advice. I hope you'll come back and let us know how it ends up.
Mike
TV = 2017 Ram 3500 (aka FRAM)
5er = SOB (2019 Grand Design Reflection 367BHS)
walaby is offline   Reply With Quote
Old 08-22-2020, 10:27 AM   #11
Speaking for myself I don't think I'd accept a repair job on a 35 day old trailer.
Haven't seen the damage but if the tongue bent at the junction with the frame there could be a lot more damage hidden within the structure.
Even if it was just as simple as cutting off and welding on a new tongue, there are "welders" and there are "welders". Those who weld for a living versus someone working in a dealer's shop "who welds" can produce two widely different results.
Best course would be to get your insurance company involved. Ultimately they will have a stake in the trailer and won't want to see future failures.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 08-22-2020, 10:52 AM   #12
The minute you bring the attorney discussion into it you’ve automatically formalized the whole thing. Usually you can’t go Kings X and go back once that’s started. There may be a time and place to do that, but in my experience that’s usually after all attempts to reach fair resolution have failed.
I’m with most other folks on this, I’d want the trailer replaced. How you do that, whether thru insurance or solely thru the dealer depends on the folks involved, but that would be my goal.
2016 Berkshire XL 40A towing 2020 Jeep Wrangler unlimited.
Prior to this Jayco fifth wheel: 24' Eagle, 30'Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 08-22-2020, 11:17 AM   #13
Thanks everyone for the replies. I went to the dealer this morning to check out the trailer. After speaking with the owner he said he will not replace the trailer as it was just an accident and it’s not that big of a deal. He did show me video footage of the trailer being dropped and sliding. He would not send me the video.
After speaking with him and getting nowhere I’m going to contact an attorney.
Old 08-22-2020, 11:21 AM   #14
Oaklevel's Avatar
I would go through your iinsurance first, going through an lawyer will just end up costing you in the long run.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 08-22-2020, 11:27 AM   #15
X2. The lawyer would probably refer you to the insurance company.
Old 08-22-2020, 11:44 AM   #16
Flybob's Avatar
I am certain it was an accident and not on purpose, but that does not relieve the dealer of the responsibility. He has insurance to cover his accidents. The best solution is to contact your insurance company and let them work it out with the dealers ins company. Your insurance company has an interest in making having solution does not put them in further liability in the future.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-22-2020, 01:12 PM   #17
Let the insurance companies resolve it
I would notify my insurance right away and ask them to resolve the issue with the sellers insurance provider. You can then speak to the seller and make your demands with them personally. I would ask for a replacement trailer. Good luck to you.
Brad Applegate
Southern Washington
2015 Rockwood Signature Ultra Lite 8289WS, 2019 Ram Longhorn Diesel
RedhawkCC is offline   Reply With Quote
Old 08-22-2020, 01:26 PM   #18
Lots of good advice here. I'd definitely talk to them face-to-face. They are liable for the damage and they have insurance. Based on personal experience with body and frame repairs, you may deal with anxiety every time you take a rig on the road following a major repair. If they won't give you a new trailer (they can fix and sell the previous one) I would get your insurance company involved. This was a new trailer going into the shop, and should be a new trailer coming out. And, as pointed out, if you agree to let them fix it, you can probably expect to wait a long time to get it out of the shop.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 08-22-2020, 01:27 PM   #19
Contact your insurance company first. Make good notes on what transpired when you talked to the dealer now while it is all fresh in your mind. If you go to an attorney, then two firms will make a lot of money, it'll take forever to get the rig back, and you'll not be happy. The insurance underwriter has folks who've dealt with this type of issue before and can run it thru to fruition faster. Not sure on how happy you'll be, but usually insurance companies do pretty well.
Greg 'n Deb
2020 R-POD 195 HRE
'17 Tacoma 3.5L,'07 Tundra 5.7L w/ tow pkgs.
Dirt Sifter is offline   Reply With Quote
Old 08-22-2020, 02:20 PM   #20
D W
D W's Avatar
X2. No excuse for a 35 day old trailer to have collision damage due to negligence of the dealer. The forklift drivers are too lazy to get off the forklift and lock the coupler!
2016 Salem 27RKSS
D W is offline   Reply With Quote
trailer
