Old 07-17-2017, 06:02 PM   #1
Trickle charger
My battery on my 2015 274dbh only holds a charge for a few days. I want to buy a solar trickle charger for it. I only need it when I'm not using my camper. Does anyone have any good recommendations? Thanks
dvdj2quick is offline   Reply With Quote
Old 07-17-2017, 06:24 PM   #2
Flybob's Avatar
Battery Tender
https://www.amazon.com/Battery-Tende...y+tender&psc=1
Ctek
https://www.amazon.com/CTEK-56-158-A...attery+charger
I personally like CTEK a few more functions, but either will work fine.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-17-2017, 06:59 PM   #3
why does it only hold a charge for a few days? are there loads connected to it? typically there are some 'parasitic loads that will run down a battery in a short time. have you installed a battery disconnect switch to completely remove all loads from the battery? a fully charged battery without loads will keep its charge for several months. have the batteries been discharged to the point of damage? if so, a trickle charger may not keep them charged? pull them out and have them tested.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is online now   Reply With Quote
Old 07-17-2017, 07:08 PM   #4
WolfWhistle's Avatar
http://www.forestriverforums.com/for...el-139382.html
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
