Old 07-10-2023, 02:43 PM   #1
Upgrade mattress for bunkbeds
One of the first things I did when I purchased my 26DBH was to replace the mattress the trailer came with. Now that my kids are a little bigger, they are complaining about the mattress, if I can even call it that, on the bunks. They are an odd shape. Does anyone know where I can upgrade the mattresses?
TTnewbie is offline   Reply With Quote
Old 07-10-2023, 03:36 PM   #2
Rhumblefish's Avatar
If you don't want to start from scratch, TTnewbie, you can purchase foam/foam toppers and cut them to size/shape.
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
Rhumblefish is offline   Reply With Quote
Old 07-10-2023, 04:00 PM   #3
rsdata's Avatar
i topped my mattresses with cheap foam rubber waffle pad... 1 1/2 inches thick from Walmart and they sleep fine... covered both the mattress and foam with a mattress pad to keep them together... of course you can also spend more on a more expensive and thicker topper
2014 Shamrock 183
Old 07-10-2023, 06:29 PM   #4
look for a local upholsterer
they can make you a foam mattress ...
some of them even have some common sizes in stock
If your covers are still good they can re-sew them to accept a thicker foam insert
or ............ just add a piece of foam under your existing mattresses
once you put a sheet over them you won't notice
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 07-11-2023, 06:52 AM   #5
Thanks for the advice. I am going to try both suggestions starting with the mattress pads. There is an upholstery place near me so I am going to check them out too. I never thought about resizing the "mattress cover" that I have now to fit a larger pad. It would look a bit cheesy to throw a thicker foam pad in the bunks without a cover on them.
Old 07-11-2023, 07:12 AM   #6
Have you checked out RV Mattress.com? They make all sizes of RV mattresses. They are a US company located in Phoenix, Az.
2020 Cherokee Wolf Pup 16FQ
2018 Honda Pilot AWD
2015 Rockwood Freedom 1950 pop-up
2009 Honda Odyssey
Multiple tents and an early 90's pop-up.
Bourbonfan is offline   Reply With Quote
Old 07-11-2023, 07:35 AM   #7
TTnewbie, you say you want to “upgrade” the mattress, but what does that mean? What is the complaint? Are you looking for something softer or firmer? People often recommend toppers, but I’m guessing they are mainly for making a firm mattress softer, not a soft mattress firmer. I am in need of a firmer mattress in my RV, and looking for options. So far, complete replacement seems to be the answer.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 07-11-2023, 09:06 AM   #8
My kids are complaining that they feel the wooden board underneath them as they sleep. The "mattress" pad that came with the trailer is not that supportive or thick. Im looking for something thicker that they can sleep on and not feel the board underneath them.
Old 07-11-2023, 10:28 AM   #9
I like air mattresses as you can make them as firm as you wish, but I have no idea if that will work in your bunk situation.
Old 07-11-2023, 10:42 AM   #10
Amazon, Zinus mattress.
They have them in RV/short Queen AND in RV bunk sizes.
I removed my upper bunk and replaced the lower bunk mattress with the Zinus 8” foam so my adult size grandson can use it. I slept in it myself when my granddaughter camped with us. I was getting up a lot at night, master bed is east-west, and it was easier to have her sleep with Grandma. Plenty comfortable.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, SumoSprings, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 07-11-2023, 02:36 PM   #11
The bunk mattresses are an irregular shape so a typical mattress doesn't fit.
https://www.campingworld.com/dw/imag...?sw=800&sh=800
Old 07-14-2023, 03:50 PM   #12
Try Tochta mattress
They made a mattress for me and I am very satisfied
Gsalet is offline   Reply With Quote
Old 07-14-2023, 04:37 PM   #13
Just about...
Just about every mattress store will make mattresses to custom sizes, usually with only a small charge or no charge over the standard size. This seems to be a holdover custom from the days when bed frames weren't standardized. Just ask your local mattress store--even the discount outfits.
By the way, I don't ever seem to remember seeing a mattress store that didn't have a sale going on. Is it the same where you live?
Larry
Larry-NC is offline   Reply With Quote
Old 07-23-2023, 08:14 PM   #14
I went to walmart and bought a 4" gel memory foam pad. I cut it to fit including cutting the diagonal corner off. I bought a topper cover I put the pad in and I just fold the excess cover under the pad. I leave the original pad under the 4" pad as well.
ProCharger is offline   Reply With Quote
bed, beds, bunk, mattress, upgrade
