Old 10-20-2020, 11:01 AM   #1
Water check valve & Low point drains Wolf pup
My city water check valve preventing filling the FW tank has failed. I found a ZURN 1/2 male to male one for 16.39 on Amazon. Is this the correct one?
Low point and FW drain fittings. Again, 1/2? Found ZURN PEX valves for 10.56 each.
The check valve I need, the drain valves Im considering. My concern on the drain valves is ground clearance.
2019 Cherokee Wolf Pup 16BHS flipped axle
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, TBC, Tow Mirrors, 3.55, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
check, drain, valve, water, wolf pup
