Water check valve & Low point drains Wolf pup
My city water check valve preventing filling the FW tank has failed. I found a ZURN 1/2” male to male one for 16.39 on Amazon. Is this the correct one?
Low point and FW drain fittings. Again, 1/2”? Found ZURN PEX valves for 10.56 each.
The check valve I need, the drain valves I’m considering. My concern on the drain valves is ground clearance.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
