Originally Posted by kevinB24
Can a water tank sensor go bad? I leveled my rv then filled my water tank at the house and once it came out the overflow drain I closed the valve and stopped filling. My sensor reads 2/3 full but if it is coming out the overflow I assume it's full. Is that a fair assumption?
Also when I got to camp (boondocking) I opened the valve and it drained for 10 minutes. Is that a problem? Sensor still reading 2/3 full, but it seems like a lot of water came out.
Depends on how fast you were filling it and how tight the fit was at the fill opening. Got to let air out while filling. I fill mine via a flow meter and slowly. I can get water coming out at half full if filling too fast. Find your tank size and fill with a flow meter. You will know for sure then.
Second paragraph is not clear. Drain it after camping to empty for the trip home? If so something is amiss if still reading 2/3.
I don't trust any of my sensor readings, especially the black. I have a good idea of how much water I use on a daily basis and how fast the black tank will fill up. I put in as much as what I will be needing via the flow meter when I will not be hooked up to water. No sense putting in 50 gallons when I know 30 will do for the time I need it.
Even though I do not trust the sensors it appears I have about 10 gallons of water left at the 1/3 reading on the fresh tank.
