Old 08-10-2024, 05:42 PM   #1
What Kind and Color A/C unit?
I do a lot of boondocking in my 2017 wolf pup 16BHS, so I don't use the A/C much. But I'm planning a long trip next summer and I'm checking out and doing maintenance on my A/C unit. So maybe someone would know some answers to some questions.
1st - My A/C is a Dometic, seems every one I talk to has a coleman. Is this a replacement or were Dometics also used?
2nd. - The cover over the A/C unit is black. Seems everyone elses is white? Do you think the color effects its efficiency? It would be a quick and easy rattle can job to make it white? Is it worth it?
So what do you think? Am I ok or should I paint it?
Rick & Akela(GSD)
GoingNoWhereFast
2017 4runner SR5 with mods
2008 Aliner Classic with Many Mods (in Rehab)
2020 FR Wolf Pup - 660watts Solar, 300AH LiFePO4, Inverter, WFCO-LIS converter, And many mods
GoingNoWhereFast is offline   Reply With Quote
Old 08-11-2024, 08:38 PM   #2
Virginian's Avatar
Hey Rick,
I have a 2019 Wolf Pup, and it came with a Dometic A/C.
Mine is white, but I did recently see a lengthy discussion of white vs black on another forum, and one of the posters noted that it made a significant improvement on his when he painted the black cover white. It sounded like a worthwhile modification.
BTW, I've enjoyed a number of your videos on YouTube.
2019 Wolf Pup 16FQ
2013 F150 5.0 STX SCab 4x4 SB/3.55 rear/tow pkg./36 gal. tank/1695 Payload/7350 GVWR
Andersen Hitch
Virginian is offline   Reply With Quote
Old 08-11-2024, 09:30 PM   #3
Thanks Virginian. mine is actually a 2020, I thought I editted it and made it correct, but now it is too old. I think I will spray it white, or maybe yellow... Black just isn't my color!
Rick & Akela(GSD)
GoingNoWhereFast
Old 08-11-2024, 10:04 PM   #4
NXR
NXR's Avatar
Here, have five recent pages of differing opinions on whether the shroud color matters as well as several irrelevant examples of why it does or does not: https://www.irv2.com/forums/f59/the-...ds-651855.html
If you're going to be in 110+ temps it may matter but putting a sun shade or a camping chair over the top of the unit to block the direct sun may be a better idea.
A few people with the Atwood units very recently reported over-temp shutdowns when the outside air temps were 115 in Arizona and some place else. Their thermostat gave an error code indicating the outside coil reached 154 F. A white shroud may give you a few degrees more margin but a sunshade over the unit probably would be better.
The OP had a Sample Size of Two to prove his point and one was using 20 year-old HVAC technology. Not the best of statistics that...
Ray
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
