Old 09-02-2020, 10:17 PM   #1
What Roof Material?
Hello I have a 2017 Forest River, Cherokee Wolf Pup 16fq. Does anybody know for sure what type of roofing material is used on this model by the manufacturer? EDPM or TPO?
Thanks,
Ken,
KenS999 is offline   Reply With Quote
Old 09-03-2020, 02:49 PM   #2
Thanks,
Ken,
EPDM (rubber) roofs are almost always have a smooth surface texture.
TPO roofs ( a form of plastic) have a fine texture to them.
My 2018 MicroLite has a TPO roof which is supposed to be longer lasting than an EPDM roof.
Sight unseen I'd wager you have a TPO roof.
Take a look and you should see which roof you have.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 09-03-2020, 03:23 PM   #3
Okay thank you
Old 09-03-2020, 06:47 PM   #4
If the roofing material is the same color top and bottom, it is TPO.
2018 F 150 Supercrew 6.5 bed 3.5 EB Max Tow
Jfkmk is offline   Reply With Quote
Old 10-24-2020, 07:52 PM   #5
Thanks,
Ken,
Ken - did you figure out your roofing material?
Griff5890 is offline   Reply With Quote
Old 10-24-2020, 09:36 PM   #6
No I have not, currently enroute to my winter home. After I get settled, thinking of pulling down the roof vent frame to see if the roofing material has black backing or not as another poster suggested . Thanks, Ken.
Old 10-28-2020, 11:18 PM   #7
Well I lost the roof vent lid heading down to my winter home so I had to take the vent frame down in order to replace the lid. Was able to see the roofing material underside. Underside is white. And rather thin I might add.
roo, roof
