06-23-2020, 01:56 PM
Long time camper.
What to do with the gen in rain
When boondocking, how do you use your generator in the rain?
Samtummo
06-23-2020, 02:10 PM
Let it rain, it's not going to hurt it.
2019 Ram Bighorn, CC/SB 2500 4x4 6.4L/8 Speed, Max Tow 14,460 lb/2,940 lb payload.
2019 F-150 King Ranch 3.5 Eco, 12,800 lb/1,546 payload.
2020 Coachmen Apex UL 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 IronBull 22'x102" 14K GVWR Equipment Trailer
06-23-2020, 02:34 PM
Long time camper.
Manual specifies “do not operate gen in rain, electrocution possible”.
Samtummo
06-23-2020, 02:36 PM
Fonzie
06-23-2020, 03:06 PM
Here is a Google search of the forum for generator tents.
Google: FRF: generator tents
Here is a Google Search of generator tent images.
Google Generator Rain Covers
I've seen everything from a PVC pipe driven into the ground beside the generator with a golf umbrella zip tied to it... to folded up yoga mats... to plastic dog kennels... to tarps over a PVC frame... to three pieces of Coroplast (plastic cardboard)... to commercially made tents.
Let your imagination run wild!
Just make sure you give it enough air!
Days Camped: '18=51 ☼ '19=58 ☼ '20=110 ☼ '21=15
06-23-2020, 03:16 PM
Slide it underneath your truck.
06-23-2020, 03:20 PM
Ask a construction contractor about it... Run it.
But in the ultra conservative, land of weight police... Build a shed around it and put a security system on it
06-23-2020, 03:22 PM
I do that sometimes.... drop the tailgate and it resides there... or under a slide out...and no... I have NO concerns of carbon monoxide with the exhaust pointed away from the R/V.
06-23-2020, 03:28 PM
Samtummo
Corporate CYA statement.
06-23-2020, 09:54 PM
Mine is on a rear bumper platform. Two pieces of emt tubing 3' long fastened to handles of my Champ 3500 with zip ties.
A 3' x 3' tarp draped so ehaust and intake are open and held in place with bungee cords.
Keeps it dry even in a downpour.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
06-23-2020, 10:06 PM
I run mine from the truck bed covered by the tri-fold bed cover with both ends open for ventilation. Gens sit between the wheel wells, covered, ventilated, and I don't even have to unload them.
2016 Ram 2500 CTD 4x4 Big Horn
2017 Coachmen FE 292bhds
06-24-2020, 09:03 AM
I've been using generators for construction in the rain for 20 years and the only time someone got a shock was due to a broken cord. Compo requires GFCI breakers on all jobsite generators here but guys hate them since they're notorious for being overly sensitive in the rain. I've used mostly just Honda generators, and they're built like a tank and handle the worst kinds of abuse on a jobsite and still run like they're new. If you've got a cheap make, it might be worth protecting it as they're likely not made to handle the abuse and rain could cause issues like rust or internal electronic faults. In a pinch I'd just put it under the tailgate, a little rain shouldn't hurt it. Longer term exposure I'd follow some of the ideas others have mentioned.
06-24-2020, 09:33 AM
I have run mine in the rain and snow when I got caught unprepared. No problem.
But I do like to keep them out of the weather (especially the sun out here) so that's why, after 13 years, they still look and perform good as new.
Pic has tarp removed.
Scott and Liz - Southern NM
06-24-2020, 11:23 AM
Just a simple tarp here, as we didn't use the generator too often. My main source of power is a solar system. The generator was well wrapped and the tarp secured with bungies.
Dave in SK
VE5DLC
Trailer: 2011 Cedar Creek Silverback 35K
Truck: 2006 Dodge 2500 TRX4 Cummins
Seasonal at Saskatchewan Landing Provincial Park
06-24-2020, 11:47 AM
I put a folded tarp over the top covering the electrical connections in the rain but leave both ends open for air in/out. I have also left it in my covered truck bed partially opened but not enough to get it out...not that it could not be pried out but just enough to not make me an easy target.
06-24-2020, 12:13 PM
I use the Champion generator tent.
2018 Wolfpack 24PACK14+
2008 Toyota Tundra
2017 HD Limited
06-24-2020, 02:52 PM
06-24-2020, 03:20 PM
Excellent solution!!!!!
06-25-2020, 08:07 PM
I have my generator tied down to the luggage rack on the back of the trailer. I have a tarp that's folded in such a way that it completely covers the generator when in transit, then I can remove the two ratchet straps wrapped around the generator and lift the tarp up on the ends which allows for air circulation but keeps the rain off. We've used it in some pretty hard downpours and haven't had any problems.
