Old 07-26-2020, 06:44 PM   #1
Wheel bearings
So I have a 274 dbh. And I was thinking that this summer I should re- grease or re pack the wheel bearings. I don't move it much, just down the mountain in the fall and up on the spring. I'll be shocked if I have put more than 1000-2000 miles total on it. Anyways I hate working on cold ground so I want to do it while it's still warm.
So my question is does anyone know what the part number for the bearings and seals. I'm pretty sure they are Dexter 3500 axles, please correct me if I'm wrong. I also believe they are easy lube axles being that they have a rubber boots at the end and a grease zerk behind the rubber boots.
Bedlinedf250 is offline   Reply With Quote
Old 07-26-2020, 07:05 PM   #2
rsdata's Avatar
Lots of resources here...
https://www.dexteraxle.com/
clcik on top for RESOURCES like service manuals with part numbers... those bearings can be found on amazon among other places
2014 Shamrock 183
Old 07-26-2020, 07:06 PM   #3
Why replace the bearings?
NavyLCDR is offline   Reply With Quote
Old 07-26-2020, 07:10 PM   #4
rsdata's Avatar
doesn't everyone care a spare set in case of on-the-road middle of nowhere axle problems?
I don't believe the OP stated he was replacing his...
2014 Shamrock 183
Old 07-26-2020, 07:16 PM   #5
Retired Old Fart
dward51's Avatar
If your 3,500lb axle takes the same set as most of the others, Amazon has the Timken grease seal and bearing/raceway sets (also Timken). Grease seal is #473336, and bearing sets are #17 and #4 (one is inner and the other is outer set, I forget which one is which). You will need one of all 3 for each wheel hub. All sold and shipped by Amazon, mine were all genuine Temkin when received.
https://www.amazon.com/gp/product/B001544U88
https://www.amazon.com/gp/product/B000X3EPWS
https://www.amazon.com/gp/product/B000IX99RO
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 07-26-2020, 07:16 PM   #6
I do just cause..........
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 07-26-2020, 07:19 PM   #7
Not necessarily replacing them but whenever I do bearings on my truck I like to have a set on hand because you never know what it's going to look like when you open up a hub. Also it's not like you will never use them at some point you will have to replace them.
Old 07-26-2020, 07:23 PM   #8
Thank you
Old 07-26-2020, 07:26 PM   #9
K. I just didn't realize trailer bearings failed at that much higher rate than vehicle bearings.
Old 07-26-2020, 08:16 PM   #10
You still have a vehicle with tapered roller bearings in it?
Personally, first thing I did after I bought my trailer was replace all the chinese bearings and races with US made Timkens.
babock is offline   Reply With Quote
Old 07-26-2020, 08:22 PM   #11
Oaklevel's Avatar
I do I have at least 3 vehicles with tapered bearings, not sure if one is still considered a vehicle though....
No I do not carry spare beairnigs for our trailers. 35 plus years of plulling trailers never had one go bad on the road.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 07-26-2020, 09:30 PM   #12
I found them cheaper at rockauto.com. I do carry a set bearings with me.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is online now   Reply With Quote
Old 07-27-2020, 01:21 AM   #13
Yep...me too.
bearings, wheel
