Old 12-03-2020, 06:37 PM   #1
Wolf pup 16bhs water heater bypass help!
Hi everyone! Hoping someone can help a newbie. Trying to determine which way the valves on my water heater need to be directed for normal use vs winterized setting. I’ve been getting contradicting answers on line. Pic is how they are currently set. Thanks!!!
Ps sorry for the pic being sideways, not sure how to rotate
Outdoorliving is offline   Reply With Quote
Old 12-03-2020, 06:53 PM   #2
wmtire's Avatar
Attachment 244078
They are positioned now for normal use. Turn both 90 degrees for winterization/bypass
Also see post #4 in this thread for your setup.
https://www.forestriverforums.com/fo...st-103381.html
2011 Flagstaff 831 RLBSS
I often say to myself, "I can't believe that cloning machine worked."
Old 12-03-2020, 06:57 PM   #3
wmtire's Avatar
Since you stated you are a newbie, this thread may also help and is aimed at some of the more common things new owners need help on. It will have many thread links including the one I posted above.
Welcome to the forums.
https://www.forestriverforums.com/fo...ts-157524.html
Old 12-03-2020, 07:46 PM   #4
Thanks for the info! Appreciate the additional links
Old 12-04-2020, 01:34 PM   #5
When you doubt yourself in six months, just remember the handles point to the direction of flow.
I finally remember
2019 Cherokee Wolf Pup 16BHS flipped axle
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, TBC, Tow Mirrors, 3.55, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 12-04-2020, 04:11 PM   #6
Attachment 244078
The valves are not on/off valves they are diverted valves. Either in use or by-pass. The handles are on line with and tell the direction.
bzac1954 is online now   Reply With Quote
Old 12-04-2020, 06:37 PM   #7
Just as confused as you
Scrapper's Avatar
Get some of those manila card-stock tags and draw the position of the valves on it, Summer on one side, Winter on the other. Hang it on the top hot water line with string or zip tie on the back of the water heater. I've done it for every rv I've owned.
Name:	Bypass-Winter manila card stock tag.jpg
ID:	244117   Click image for larger version
Name:	Normal-Summer manila card stock tag.jpg
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Old 12-04-2020, 06:40 PM   #8
wmtire's Avatar
That's a pretty neat idea.
Old 12-06-2020, 06:44 AM   #9
Very cool idea, thanks!
heater, water, water heater, wolf pup
