Old 10-24-2023, 12:28 PM   #1
Wolf Pup furnace removal
Anyone know how to get the furnace out of a Wolf Pup 14CC? Ours makes a loud rattle as it's warming up, like something is vibrating inside. I can get to the wires and the gas line, I can get the grille off and remove the screws from the front, but something is attached at the rear. I just can't see what's attaching it. Do I have to take the outside vent off first?
2023 Wolf Pup 14CC
2021 Ram 1500 4x4 3.6 V6
dsherman26 is offline   Reply With Quote
Old 10-24-2023, 12:59 PM   #2
my guess? Pull harder. I can only attest to what my 2017 16 bhs removal was like. remove gas line, cut wires, two screws in front bottom removed, and pull. The fit to the exterior tubes is tight on the exhaust for obvious reasons, but did pull out with a little wiggle and effort.
ejl923 is online now   Reply With Quote
Old 04-06-2024, 12:17 PM   #3
Took a while to get to it, but that was the secret. Undo the wires and the gas lines, take out the screws at the front, then just wiggle it and the pipes let go. Turned out I had leftover pieces of the aluminum in the back of the furnace, and more sawdust. Yeah, those are good things to have inside a furnace...
2023 Wolf Pup 14CC
Old 04-06-2024, 05:55 PM   #4
glad it worked out! I used blade connectors when hooking back up, so if it has to come out again, no more cutting
furnace, wolf pup
