Old 07-18-2021, 09:56 AM   #1
120v AC and USB ports not working. Help please.
We have a 2017 DX3 37BH. We are connected to 50 amp shore power. All appliances and AC units are working. However, 120v outlets and USB outlets are not working.
The outlets were working in a different campsite yesterday with 50 amp, and we just lost use of the outlets today at this new campsite.
We have read a lot of electrical threads here, but haven't found the solution yet.
Wondering about GFI reset, but don't know where that is?
Any other suggestions would be appreciated.
Thank you.
2017 Dynamax DX3 37BH
content is offline   Reply With Quote
Old 07-18-2021, 10:06 AM   #2
I found the GFI reset. For reference, it is behind the panel next to the fuses on the main bed pedestal.
It was tripped, and so I reset it and that solved the AC outlets
However, usb still not working.
Old 07-18-2021, 10:08 AM   #3
Glad you got it figured out, and in only 12 minutes between posts.
Thanks for letting us know you got it resolved.
Marc in sunny California
2013 Crusader 260 RLD
2012 RAM 2500 Laramie CTD and 4:10
mmartin_tdc is offline   Reply With Quote
Old 07-18-2021, 11:58 AM   #4
KRedburn's Avatar
Do you maybe have a battery disconnect in OFF position?
I have inadvertently pressed the disconnect switch on the entry panel at times.
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
KRedburn is offline   Reply With Quote
Old 07-23-2021, 07:47 PM   #5
[QUOTE=KRedburn;2600607]
However, usb still not working.[/QUOTE]
I am aware of the coach battery disconnect in the battery bay, and the engine battery disconnect on the floor by the driver's seat. Neither of those is in the OFF position.
Is there another battery disconnect, or something else the might cause the USB ports in the bathroom and bedroom to not work?
Old 07-24-2021, 10:40 AM   #6
Motorized GM
[QUOTE=content;2604150]
Define "not working". What are you plugging in? Some devices require more power than thsoe USB's might provide. mainly iPad Pro's...some things that have converted to USB-C (which normally require more power).
If that device works in another USB of the same exact style, then it could be a fuse.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
bclemens is online now   Reply With Quote
Old 07-24-2021, 06:06 PM   #7
[QUOTE=bclemens;2604367]
We are plugging in cell phones that have always charged fine on these USB ports. The USB ports stopped working about the same time as the 120v GFI outlets. The 120v GFIs came back to life with the breaker reset. Which fuse is for the coach USB ports?
Thank you.
Old 07-24-2021, 06:16 PM   #8
KRedburn's Avatar
I have inadvertently hit this switch which is momentary.
The coach does not work 100% if this light is not lit up.
Name:	entry panel1.jpg
I have no usb ports in my coach other than ones that I have put in.
Old 07-24-2021, 06:37 PM   #9
Motorized GM
[QUOTE=content;2604622]
Thank you.
outlets are 110V, USB's are most often 12V, so two completely different systems, unless it is a "plug in style" outlet with USB's.
So in the main panel under the bed where you reset the 110V GFI breaker, near that would be the main fuses. Could be a fuse blew or the USB's just died. it happens. I would pull the USB and see if it has power to the outlet (12V), if it does it is the outlet. If it does not, then it is a fuse.
Old 07-24-2021, 09:19 PM   #10
Attachment 259761
Thank you for your time and courtesy posting the photo! We don't have that switch panel in our coach that we are aware of.
Fortunately we bought a cigarette lighter to dual USB that we use in the cab while driving, and we just bought a 120v to dual USB that we can plug into any 120v outlet when the generator is running or when we are on shore power.
Thanks again
Old 07-24-2021, 09:20 PM   #11
[QUOTE=bclemens;2604642]
Thank you Brian
Old 07-25-2021, 06:47 AM   #12
Attachment 259761
Content...
Funny, I have the same year and model as you do and I have that same panel.
Curious as to why you don't???
any thoughts?
Joe
Toad: 2020 Ford F-150
joet19711 is offline   Reply With Quote
Old 07-26-2021, 09:27 PM   #13
Originally Posted by joet19711 View Post
Content...
any thoughts?
This is a photo of the switches at our entry door. Not sure why the difference? These switch panels do not have a disconnect switch.
Name:	Entry controls and switches photo.jpg
Old 07-27-2021, 07:11 AM   #14
Motorized GM
We converted to multiplex wiring mid model year, one floor plan at a time.
