Old 08-04-2021, 06:43 AM   #1
Invisibleman's Avatar
21 Force HD leveling jacks make loud creaking when retracting
When I raise my leveling jacks they make loud creaking sounds like they are straining and the entire coach shakes. This is always, and doesn't depend on how level or solid the surface is I've parked on. It feels like it mostly the rears, but haven't determined that for sure. And it appears to be more than one jack. They extend normally and quietly other than the pump. And they do fully retract, just noisily. It's actually noisy enough, it turns heads nearby.
2021 Force 37TS (Detroit DD8)
2021 Jeep Grand Cherokee Trailhawk
2020 Isata-5 36DS (traded in)
Invisibleman is offline   Reply With Quote
Old 08-04-2021, 07:13 AM   #2
MoJoe1003's Avatar
It happens on mine occasionally. Seems to happen more if I have dumped the rear air before leveling. The sound can be a little disconcerting at times. I have Snap Pads on the feet so I don’t get the noise of the metal pads slipping on the surface like I did before I installed them. Mine sounds more like the shafts being dry and then the seals rubbing on the metal shafts as they retract. Never has seemed to affect the operation of the levelers though.
Joe & Cynthia
2021 Dynaquest XL 3801 TS Cindy 'B'
2021 Jeep Wrangler Unlimited Rubicon Diesel
“Breathe in, Breathe out, Move on”
MoJoe1003 is offline   Reply With Quote
Old 08-04-2021, 07:17 AM   #3
Yes. I'd agree it sounds more like the shafts than pad slippage. But I haven't had the opportunity to actually watch while they are raising. Next time I'll auto raise and scoot out and watch. Haven't gotten snap pads yet.
Old 08-04-2021, 08:08 AM   #4
See this thread by @RV Randy starting on post #10:
https://www.forestriverforums.com/fo...ks-155989.html
It works.
2018 DX3 37BH
mookieblaylock is offline   Reply With Quote
Old 08-04-2021, 08:35 AM   #5
MoJoe1003's Avatar
It works.
Thanks for posting that thread. I probably would have never found it if I tried. Good stuff.
Joe & Cynthia
Old 08-04-2021, 09:17 AM   #6
Thanks. I will definitely give it a try.
Old 08-04-2021, 10:04 AM   #7
Commercial Member
While it may not tell you what it will fix (I'll see if they can add that to the manual), the instructions are on page 7 of the manual
https://forestriverinc.help/#/dynama...ultiple-709148
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 08-04-2021, 12:21 PM   #8
I've been thinking about the Snap Pads to eliminate the metal scraping noise. Are you satisfied with the Snap Pad performance?
2021 Dynaquest 3801TS
2023 Rubicon JLU Xtreme Recon
2020 Jeep Wrangler Limited Willys
MAC D is offline   Reply With Quote
Old 08-04-2021, 04:06 PM   #9
MoJoe1003's Avatar
Love ‘em. Added advantage is not having to carry the plastic pads to put under the jacks when on softer ground or in RV parks that require pads of some sort. First thing I put on the 2021 XL when we traded the 2018. Had them on that one as well. Once you put them on there is no removing. At least not for reuse on another coach.
Joe & Cynthia
Old 08-05-2021, 05:55 AM   #10
Good to hear! I'll get them on order now that I don't have to be concerned about them falling off.
Old 09-01-2021, 12:19 PM   #11
Went through the process, and installed snappads. Everything smooth an quiet now.
jacks, leveling
