Quit Worring....I got it fixed....wanna know how? :)
So I downloaded the worthless manual for the AC unit that does not even mention HeatPump capability. Same manual comes with RV.
I downloaded the manual for the Thermostat and that was very informative. It was not 'Locked Out' per se due to cold. That temp is outside temp = 25 degrees.....I know this unit will operate at 31 based upon several days of Elkhart having that temp when I woke up. (Greg likes to begin work at 0600)
In HEAT-PUMP modes, a flashing HEAT-PUMP
icon indicates that the unit is performing an autodefrost.
In HEAT-PUMP+FURNACE mode, while auto-defrosting,
the unit will use the furnace.
So I let the unit run in that mode for 30 min. Still not able to get the heat pump to start. I then searched for the 12 volt fuse that would shut it down. Yes, the GE unit runs on 12volt. Found fuse, both Thermostats went dead....waited....Fuse in and they came back from the dead. Fwd unit now works in both AC and Heat Pump mode. Greg is really going to be happy that I fixed this....he has spent a lot of time on my RV....He is a STAR!
As soon as Micro-Air finishes their Thermostat for this GE unit, I will be getting at least one of them. By the way, Micro-Air tech support was busy emailing me on a Sat. morning helping with the troubleshooting of this problem. Micro-Air for the win!
2022 DynaQuest XL 3400KD CabOver, WD, Lithium Batteries, 4 190Watt Rigid Panels, extra inverter for AC operation w/o Genset.
