Old 08-06-2022, 10:02 PM   #1
twp5253's Avatar
22 XL Theatre Seats won't recline..vibrate yes
Hooked up to 50 amp. Normally the recliners work really nice! I have the ability to light up the cup holder and make it vibrate but it won't recline?
Not the end of the world, Oct 5th it will be in Elkhart, IA
2022 DynaQuest XL 3400KD CabOver, WD, Lithium Batteries, 4 190Watt Rigid Panels, extra inverter for AC operation w/o Genset.
twp5253 is offline   Reply With Quote
Old 08-07-2022, 03:42 AM   #2
FrankG's Avatar
Make sure all the internal electrical connectors are plugged in. You should be able to pick up the footrest and make sure the wire from the recliner motor has a secure connection.
2023 Explorer ST-Line w/Tow package
2021 Surveyor Legend 19RBLE
2018 Haulin 6 x 12 Cargo Trailer by Forest River
2017 Laredo 325RL Sold
2016 Vengeance 29V Sold
1970 Yellowstone Used as down payment for first house
FrankG is offline   Reply With Quote
Old 08-07-2022, 08:51 AM   #3
twp5253's Avatar
Wondering if Theater Seats have two fuses?
The footrest if hard to hold up. I was hoping it might be a fuse because other than having the slide out, nothing else has changed.
Old 08-07-2022, 11:22 AM   #4
Commercial Member
Known issue described on another thread. Cut 12V power, they should start working again.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 08-07-2022, 02:24 PM   #5
twp5253's Avatar
Where to cut power?
I found the three really big disconnect switches in the battery bay. Turned them off. NO joy. Then turned the cab/engine disconnect off. No Joy
The seats still had power. Perhaps the solar is providing enough...and I should try again at night?
I knew there was no way another connector could be on the flake!
Old 08-07-2022, 06:13 PM   #6
twp5253's Avatar
Yes, they are powered by 12Volt
I shut down both inverters and flipped off the 50 amp circuit. Waited several minutes and then reset the clocks as I am a pro at that.
Please, how do I shut off the 12 Volts? Mind you, my Lithium batteries were installed in Texas so perhaps that has something to do with this?
Old 08-18-2022, 01:26 PM   #7
Invisibleman's Avatar
On my 21 Force the recliners are plugged into the 120vac recepticle behind the seats, and the cup holder things plugged into the other side of the same 120vac outlet. Maybe the plug for the recliners just came out? You can look down behind the backrest with a flashlight and see. If they are not working plugged into 50A shore power, the inverter shouldn't be in the equation. And if the vibe and other cup holder stuff is working, then the outlet has power.
2021 Force 37TS (Detroit DD8)
2021 Jeep Grand Cherokee Trailhawk
2020 Isata-5 36DS (traded in)
Invisibleman is offline   Reply With Quote
Old 08-18-2022, 01:40 PM   #8
The OP is saying the recliners are 12v and Brian mentioned cutting the 12v power to reset them.
Another suggestion said they are plugged into a 120v outlet.
I suppose someone should verify whether the recliners are 12v or 120v.
This thread was started in early August and brought back to life today so maybe the issue is fixed and the OP never reported back?
Regardless, you should be able to find a disconnect in the wiring to the recliners near the recliner. I can't imagine them being hardwired.
OH... and please don't put pertinent information in the subject line of a POST.
Those reading/participating on a mobile app DO NOT see individual post subject lines. Only the original subject line.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 08-18-2022, 03:47 PM   #9
Commercial Member
Well, the answer to that question is "Both" 120V and 12V
We were 120V....those, I do not believe had any freezing issues (though if they do, then it is more likely to be "unplugged" as mentioned, OR the inverter is not enabled).
However, what we have seen more issues on is the 12V version that came later. I have described that cause in detail already.
I do think we have since gone back to 120V to eliminate the 12V related issues. I wish it was a simple as 12V or 120V... Welcome to the Covid years.
