Old 07-01-2020, 04:54 PM   #1
24fw slide out 110v question and observation
So, still working on no 110 to the slide out outlets. Had a few minutes today and found I have power at the breaker, but none at the connector under the drawer in the slider.
My question is what side of the connector goes to the breakers? I suspect the white wire.
Observation: was a little disappointing to find the one side of the connector wired hot, neutral, ground and the other side wired hot, ground, neutral. Plus some staples bridging 1/2”+ gaps in the framing... Click image for larger version
Prinflex is offline   Reply With Quote
110v, slide, slide out
