11-20-2022, 10:30 AM
28ss Water Pump & Filter Locations
Ok, folks. I understand my water pump is supposedly under the right side carpeted flooring next to my bed. I have so far found no hidden screws. Where else could it be? I'm also trying to find my water filter, which I had thought would be under my bed. This is a picture of what's under my bed. For perspective, the white tube exiting the access panel was used to winterize via antifreeze. So, this is a picture of the right side corner. When I took delivery about a year ago the coach had been winterized already.
2022 Dynamax Isata 5 28ss w/Explorer Package (Dark)
ATC 20ft CH205 Car Hauler
11-20-2022, 01:05 PM
Commercial Member
Use a magnet on the carpeted cover. Screw heads get hidden in the nap.
If "Search this Forum" does not yield an answer, please post questions as a "New Thread" (instead of sending a private message) so that others can benefit from the answers. Use Private Messages for sensitive information only.
Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
11-20-2022, 03:11 PM
Norwood Auto Italia
Definitely not where it its situated on my 28SS which was right side bed wall as you are looking down in your picture. Just where the white hose connector is placed. In fact I have used the exact same connector to bypass my filter as I have no need for it at the moment.
2000 Sportsmobile E350 EB
2006 Renegade/Peterbilt K1854 and T1220
2021 Isata 5 28SS Explorer
11-27-2022, 04:00 PM
Ok, found the screws. Thank you. One was stripped so had to pull the carpet on one side. Still no sign of water filter. Any ideas?
11-27-2022, 04:09 PM
Commercial Member
The water filter used to be next to the fresh tank...I think we moved it outside into the utility bay (last thing I knew)
11-27-2022, 04:21 PM
Was this R/V new when you bought it?
There appears to be a white plastic nipple between two lines in the very front of your photo.
This is a typical way of removing the water filter and joining the lines together.
Sent from my SM-G996U using Forest River Forums mobile app
Days Camped: '18=48 ☼ '19=58 ☼ '20=110 ☼ '21=116 ☼ '22=112 ☼ '23=32
11-27-2022, 04:22 PM
Commercial Member
Good catch. That is where it used to be installed.
11-27-2022, 05:05 PM
Yes, I am the original owner. The spot you mention is exactly where I was expecting to find the water filter housing based on other pictures I have seen. The thing is, i have had a new filter in plastic from day 1. The dealer where I took delivery winterized the unit before I took possession but I can't think of a reason they would have removed and not replaced the water filter housing.
11-28-2022, 10:30 AM
Commercial Member
Just reach out to parts with the last (6) of the VIN. Shoot them that picture
11-28-2022, 10:38 AM
I have a dark computer screen up here at shop, but can I ask what this is at the end of the red arrow?
 2011 Flagstaff 831 RLBSS
I'm trying to write a self-help book but I'm struggling. Any advice?
11-28-2022, 10:43 AM
Commercial Member
Its the strainer/pre-filter
11-28-2022, 10:51 AM
Thanks Brian.
11-28-2022, 07:06 PM
Thanks! Email sent.
11-29-2022, 10:22 AM
Parts department was very responsive and is sending me the missing parts (filter housing, filter, mounting bracket).
Thanks again!
11-29-2022, 10:51 AM
Thanks again!
Great! Good on FR!
Now do yourself a favor and do not install it inside the R/V where it is tough to get to and makes a water mess each time you service it.
Put garden hose fittings on it and mount it at the pedestal on arrival where it will filter every drop of water that goes through/into your regulator, hose and R/V.
11-29-2022, 03:33 PM
Norwood Auto Italia
Great! Good on FR!
But use a splitter at the faucet so you can get access to unfiltered water for flushing the Black tank or rinsing something outside without using filter capacity. Those filters are not cheap.
11-29-2022, 06:29 PM
Water pump location and access
I have a 2022 Europa and have convinced myself that the water pump will be under the bed. (?).
Surely I don’t have to lift/remove the mattress to get to it, do I? Help.
11-30-2022, 08:28 AM
Commercial Member
Interactive Owners Manual is your friend.
In the manual, there are all the manuals, as well as "Floor plan specific Information"
https://forestriverinc.help/#/dynama...-europa/browse
That diagram will show locations of serviceable items. The water pump is in the bed base....but, the most I have ever had to access it, is once a year.
11-30-2022, 03:38 PM
Great! Good on FR!
Funny you should mention this. While I'm happy to be getting the parts I'm running through my mind how to get everything installed, not to mention regularly swapped out, without making a mess.
12-01-2022, 09:39 AM
Great! Good on FR!
An alternate viewpoint - I like the filter housing in its existing location for a minimum pink stuff winterizing approach.
Draining and blowing out can get everything except the water pump, which will still have water and is vulnerable to freezing.
- After the draining / blowing, I remove and drain the filter housing.
- Set up a bottle of pink stuff to the inlet with valves set up to winterize.
- Start pump while watching the filter housing.
- As soon a pink stuff appears in the housing, stop the pump.
- Remove the housing, dump pink stuff in toilet. Remainder of pink stuff in bottle is used in the toilet and drains.
Dewinterizing, hook up a bottle of clean water to the winterizing inlet. Run pump until housing is almost full. Dump. Repeat. This minimizes flushing pink stuff out of the water lines.
An old towel placed under the housing can catch overflow, if you are careful.
2021 Isata 5 28ss 4x2 / 2020 JLU Rubicon
Prior: 2016 Lance 1995 / Ram 1500 Eco Diesel
2012 Lance 1575 / 2015 Jeep JKU Rubicon
