Old 09-08-2020, 06:35 PM   #1
AF CMSGT RET
28ss wiring diagram for lights?
still looking for a wiring diagram for 28 SS 2021 lights especially for the accent lights lower ones stay on even with the upper ones off and no switch or seemingly no inter connect as notes there should be. So gotta trace wires ?
pickeljr is offline   Reply With Quote
Old 09-08-2020, 07:31 PM   #2
There are no schematics, wiring diagrams, plumbing diagrams for pretty much 99.9% of RV's. Two identical MH's or TT's can be wired completely different of one another.
TheWolfPaq82 is offline   Reply With Quote
Old 09-09-2020, 12:55 AM   #3
Motorized GM
That is 100.0% false. 100% of what Dynamax builds has a pre-built wiring harness, color coded wires with the circuit stamped on the wire every 6".
Not sure why people want to come onto a sub-forum about a product they do not own and make wide assumptions about it.
I will post the schematic as soon as I am back in the office. Though I doubt it is circuit related, but likely software related.
Picklejr Are you saying even the "Master Light Switch" does not turn off the accent light?
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 09-09-2020, 02:01 PM   #4
That was my fault. I've seen you post before about the wire harness used in the Dynamax units. Too bad we can't say the same about the other 5vers, TT's that are out there.
Old 09-09-2020, 02:16 PM   #5
Motorized GM
Well, I posted that at 1 am fighting some insomnia...so I may have been a little snippy.
These are NOT properly disclaimed, just pulled raw from the drive. Properly legalized ones would be pulled from the dealer through their "Dealer Connect" portal.
Old 09-09-2020, 02:19 PM   #6
NO-NO ! No fault of your's. Why I didn't think how you've been working on putting all those together is just one of my senior moments I guess.
BTW: Nice schematics !
Old 09-10-2020, 04:37 PM   #7
AF CMSGT RET
Red face
yes I am , that light has been on since I drove off the dealers lot I have search all over it for a switch with no luck, accent on panel only turns off the top accent on counter.
Old 09-11-2020, 07:37 AM   #8
Motorized GM
I sent this to my guys....They think the stove lights or USB wring got hooked up to the kitchen base LED's by accident and not the "accent lights" wire.
The "gray and white" accent lt" should be connected to the red/black wires for the ktichen base.
You can try to turn on the stove knob lights...see if that works (or if it turns off the accent lighting).
ID:	238866   Click image for larger version
ID:	238867   Click image for larger version
ID:	238868   Click image for larger version
diagram, light, ram, wiring
