Old 08-25-2020, 01:31 PM   #1
EdandShelley's Avatar
3” to 2” Hitch Solution
I’ve not been a fan of all the parts to get the 3” receiver to the 2” receiver for our Roadmaster tow bar while providing a mount for the E-Bikes.
Worked with Gen-Y and think it’s now solved... takes two pieces out of the connections while providing 1,500 lbs tongue and 10,000 tow capacity.
ID:	237584Click image for larger version
ID:	237585Click image for larger version
ID:	237586Click image for larger version
EdandShelley is offline   Reply With Quote
Old 08-25-2020, 03:29 PM   #2
FOURWHL's Avatar
Nice work. I had the same experience after flat towing a few times. All the parts and pieces to get the reduction and a riser made for a lot of slop. I could feel the jeep more during accel/decel than my trailer. This should help with that a lot.
2016 Dynamax DX3 - Big Blue
FOURWHL is offline   Reply With Quote
Old 08-25-2020, 03:59 PM   #3
Gen Y was great... they quoted me two weeks and it delivered in one week!
Old 09-10-2020, 05:33 PM   #4
Graphicaccents's Avatar
Thank you for the info, how you you deal with the different hole sizes, the road master has smaller holes doesn’t it?
2018 Force HD TS37
2020 Jeep Wrangler Sahara
Graphicaccents is offline   Reply With Quote
Old 09-10-2020, 05:54 PM   #5
The 3” shank has a 3/4” pin hole to match the Freightliner receiver.
The 2” receivers on the Gen-Y are all 5/8” pin holes that match our tow bar pin holes.
Trying to rely on memory on the pin sizes above. Regardless, they all match. All works well together.
Old 09-10-2020, 06:36 PM   #6
Does that include the shaft that goes into the receiver, that would be a 5/8 pin hole, my receiver has a 3/4 in pin hole
2018 Force HD TS37
Old 09-10-2020, 06:37 PM   #7
I reread the post I get it now
Thank you
2018 Force HD TS37
Old 09-11-2020, 02:24 PM   #8
Don’t convert to 2”, just order a 3” weigh safe from me. All the new dynamaxes come with a weigh safe!
Pm me for details.
—john
johndjmix is offline   Reply With Quote
Old 09-11-2020, 02:52 PM   #9
FOURWHL's Avatar
Pm me for details.
—john
That's not really an option for flat towing ... which I gathered was the point of the OP and a lot of the use cases for many.
Old 09-11-2020, 03:33 PM   #10
Ahhhh true. I actually have one if those tow bars that goes right in the 2” opening. It’s the only time I remove my 3” weigh safe hitch!
—john
hitch
