Thanks for the confirmation
Originally Posted by malmz
Job done. Thanks for the input and information, they did the install today leaving the plenum in place so as not to remove any ducting or the trim ring. With the bedroom duct on the 32KD I don't think there would be access to do the plenum easily at all.
The weather cooled down to 99 so I was able to do a 5 minute test. The loud metal pop every minute is gone and problem is solved. I will send a thank you to Suburban for replacing the unit.
One more issue off the list, the main slide water ingress is next.
Thanks for the confirmation.
Larry
