Old 09-19-2020, 05:07 PM   #1
letsgorving's Avatar
Send a message via AIM to letsgorving Send a message via MSN to letsgorving Send a message via Yahoo to letsgorving
37BH upper bunk support
Upper bunk tipping toward inside of coach. There is no support/bracket holding back section on the inner wall and that supports front section in the middle. Anyone know whats in that inside bunk wall? Studs?
I know a few of you removed that inner wall. Need some advice. See pic for visual.
This is not our coach, seems our wall is longer? 2018 DX3 37BH
Kevin & Jean
2018 DX3 37BH
letsgorving is offline   Reply With Quote
Old 09-19-2020, 05:42 PM   #2
FOURWHL's Avatar
Maybe these will help 37BH Wall Print (Bunk Area).pdf
2016 Dynamax DX3 - Big Blue
https://fourwhl.com - Traveling the country in our DX3 for the next year
FOURWHL is online now   Reply With Quote
Old 09-20-2020, 09:10 AM   #3
Retired Army Paratrooper
MasterBlaster's Avatar
Looks like your screws holding that bunk up have probably worked loose. I see Brian G posted the plans for wall, that should help you. I also still have the wall I removed and will take some pictures and post them so you can get a visual of the inside.
Dennis & Zoleta
Retired US Army
Force 37BHHD
MasterBlaster is offline   Reply With Quote
Old 09-20-2020, 10:33 AM   #4
Thanks would appreciate that! Was there a bracket supporting that rear section before you removed it? We have nothing supporting that and since front piece relies on rear its leaning in
Old 09-20-2020, 01:02 PM   #5
Motorized GM
I think back there they screw right through the frame of the bunk...then they put plywood on top. So you would nee to remove either the top or bottom cover to get to the frame cavity to get to those screws.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 09-20-2020, 01:39 PM   #6
Like Brian said you will have to remove top panel on top bunk to get to the screws. They go thru the bunk frame into this wall. However this will be the rare exception in the industry where instead of using a screw every inch it will be only two probably [ATTACH][ATTACH]
ID:	239592   Click image for larger version
Dennis & Zoleta
Retired US Army
Force 37BHHD
Old 09-20-2020, 04:09 PM   #7
Good info and picks everyone, this should make it easier for us to get this taken care of. This forum with owners and GM on here is priceless. THANK YOU
Kevin & Jean
2018 DX3 37BH
bunk
