My 2021 Force 37TS has the Splendide washer and dryer. The dryer which is on top has the vent outlet on the top left corner of the unit. The vent exits directly out the side. There is an RV vent cap that goes on the outside that has a very low profile and vents straight down. I am not there so I can't provide measurements. But I think perhaps a good idea to have the units on site, with perhaps the washer in place, then measure the drying and get your dimensions. Remember there are vertical aluminum studs in that wall that you don't want to penetrate. The rest of the wall is filled with a solid foam insulation and easy drilling.
2021 Force 37TS (Detroit DD8)
2021 Jeep Grand Cherokee Trailhawk
2020 Isata-5 36DS (traded in)
