Originally Posted by rk06382
Once again, a huge argument for installing batteries in a heated area.
I believe babcock said it best "if I'm not freezing, they're not freezing.
If in storage chances are no need to keep on charge like lead acids. If spending a night in the cold, batteries will either be warmed by furnace with no extra power draw if inside. If in an outside or exposed area, adding some foam board insulation and routing some furnace heat to the "battery box" would accomplish the same thing. Lithium require so little attention the compartment could almost be sealed from the outside.
Hopefully the internal heaters work well.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
