05-31-2016, 03:16 PM
A few more Force questions
- Does the Force include a built-in air compressor?
- Why the much smaller awning on the 37BH vs the other floorplans? 13' on the BH vs 17' on the others. It seems that, with the additional people implied by the BH, you would, if anything, want a bigger awning...
- Is it possible to install the larger awning from, say, the 37TS, on to the 37BH in order to get the larger size?
- The "LP Quick Connect" listed in the Standards/Options - is that an easy hookup for things like an LP grill?
- What are peoples opinion on the Bilstein Gas-Charged Front Shocks option? What kind of ride/handling difference does it make? Is it possible to switch to those shocks aftermarket, or does the unit have to come equipped with them originally?
05-31-2016, 03:25 PM
Yes air. Model depends wether you get an outlet.
Awning is short because of the bunk bedroom slide.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
05-31-2016, 04:02 PM
Kenny answered the awning question. The HD Force has an air chuck in the battery compartment. I haven't driven anything except the Force HD with the gas shocks so I have nothing to compare to, but body roll is minimal & ride seems good from where I sit. Undoubtedly you could upgrade the shocks at a later time. Interested in a response to the gas connection.
2017 Dynamax Force HD
FRC37BH
Branson, MO
05-31-2016, 04:29 PM
2016 Sabre 36QBOK
Oh, duh - I should've realized that! I think I need some more coffee - maybe an IV drip is in order?
Thanks!
05-31-2016, 04:30 PM
Thanks!
05-31-2016, 08:41 PM
I am considering adding a cassette awning to the bh slide out, two awnings would be awesome. The shocks are great and the local Freightliner dealer said that the stock shocks are junk, and The billstein was a great upgrade. I added a safe t steer which has made handling awesome.
The propane quick connect is at the bottom of the propane tank, going to run a hose to the passenger side and direct connect to a Weber grill. There are you tube videos on hooking the grill up without the regulator.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
05-31-2016, 11:10 PM
Halla,
Did you mean Safe-t-plus steering stabilizer or is there another company called Safty steer.
I looked up Safe-t-plus and that looks like a must have.
Newbie
2 RV Trips to date
19 States
2016 Dynamax Force HD
06-01-2016, 07:46 AM
Yes, Safe T Plus out of Atlanta. Sorry about that, it was a great addition, now I am comfortable with one hand driving and it doesn't get a lot of push back when you pass semi's etc...
