Old 03-10-2023, 01:23 PM   #1
About electrical gremlins
2016 Force HD 36fks: Overhead lights in dinette, sofa slide quit working. The bathroom, bed head end overhead lights also quit, not at same time. Have the electrical schematics of the DX3 which I assume are close to the Force. Schematics are not much help as no locations of where a lot of the terminations, cluster connections are located.
Have done this:
1. Continuity at switches, no power, individual lights had been working, no flickering previously.
2. No fuses found blown, or breakers, rest of lights, electrical work
3. Checked cleaned grounds that I could find in back of rig.
4. Cleaned ceiling electrical plug that connects outside by propane tank in back of rig, which did have some water intrusion in plug, no change, and I don't think these problem light circuits connect through here anyway.
Questions:
1. Have found one fuse in bedroom marked compartment lights and one relay in front electrical cargo compartment marked compartment lights. Both test ok.
Is this all of the fuses/breakers for lights, clearly there are several coach light circuits. Anywhere else to look for light fuses?
2. Is there a termination block somewhere for coach light wiring to tie too?
Thanks for any suggestions
dmall is offline   Reply With Quote
Old 03-16-2023, 12:35 AM   #2
FORCE of Nature's Avatar
While my 37TS is not the same as yours, I saved this from a post when someone was having Porch Light power issues. The overhead lights are all run from a ceiling harness. It might be at the connectors to this harness where you have an issue. Since all the lights you describe seem to carry through the roof harness, fingers crossed it gives you an idea of something to look for. See attached (2 pages). Hope it gets you some traction in the right direction. Good luck!
D02020591 REV_E 37TS ROOF HARNESS.pdf
2022 Force HD 37TS
---- FORCE of Nature ----
22FT Full Tilt PJ Trailer for the Toad and Toys
11FT Triton ATV Trailer / Artic Cat SXS
Retired: 2011 Dutchman Aerolite/2015 FR Heritage Glen
FORCE of Nature is offline   Reply With Quote
Old 03-16-2023, 01:48 PM   #3
Great ! This electrical schematic is much better than the one I had found. Appreciate the help!
Old 03-18-2023, 05:55 PM   #4
Invisibleman's Avatar
Read this thread. A couple of us have had this issue. Yours sounds similar.
https://www.forestriverforums.com/fo...ad-258030.html
2021 Force 37TS (Detroit DD8)
2021 Jeep Grand Cherokee Trailhawk
2020 Isata-5 36DS (traded in)
Invisibleman is offline   Reply With Quote
Old 03-19-2023, 10:31 AM   #5
Yes, this does look very similar, thanks for info, will investigate these ideas!
electric, electrical
