Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-06-2021, 07:16 PM   #1
Adding filtered water faucet
Hello everyone
2021 Isata 3FW
I am hoping someone has already done this or knows, I need to know what kind of bit I would need to drill a three-quarter inch hole in the countertop. I am wanting to add a faucet to my filtered water system that I’m installing.
rockwood8283 is offline   Reply With Quote
Old 12-06-2021, 07:34 PM   #2
Bill Davis's Avatar
Originally Posted by rockwood8283 View Post
Hello everyone
2021 Isata 3FW
I would use a hole saw.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
Bill Davis is offline   Reply With Quote
Old 12-06-2021, 07:36 PM   #3
Commercial Member
The counters are just Corian. I think the consensus on the internet is hole saw or spiral drill bit.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 12-06-2021, 07:36 PM   #4
Vansteenburg's Avatar
For a solid surface like Corian, new hole saw bits work the best. Set a variable speed drill to slow, orabout 200 rpm.
Using painters tape can help minimize slip, but also good to mark on.
Don't use a Forstner or spade bit, those can ruin the material.
Aaron
2019 DX3 36FK
All Electric w/Cab Over
Vansteenburg is offline   Reply With Quote
Old 12-06-2021, 08:37 PM   #5
Love this forum!! The best!!!!
Thanks you’all
Old 12-07-2021, 08:10 AM   #6
Webefine's Avatar
I just recently cut out my solid surface kitchen sink and installed a single bowl stainless. I used standard drill bits and jig saw blades and had no problems cutting or drilling the solid surface material. A hole saw should work fine.Click image for larger version
Webefine is offline   Reply With Quote
Old 12-07-2021, 10:50 AM   #7
FOURWHL's Avatar
Fwiw if it saves some hassle I just installed the filter on the cold line of the faucet.
2016 Dynamax DX3 - Big Blue
Full-time Dynamax Resident
FOURWHL is offline   Reply With Quote
Old 12-07-2021, 01:40 PM   #8
I am thinking of doing the same thing. Only instead of tapping the cw line I want to add a separate 10 or 11 gallon tank with its own pump and fill port. I have room under one of the dinette benches. It would increase the fw capacity from about 50 gallons of fw. Now we take gallon jugs from home filled with our home water for drinking, coffee, etc. I will for sure use a hole saw and might even clamp a scrap of wood over the hole before drilling to make sure I get a clean hole.
markb422 is offline   Reply With Quote
Old 12-07-2021, 04:53 PM   #9
curteric's Avatar
If the counter top is Corian, use a hole saw and finish with a green 3M Scotch Brite pad. That’s how we used to do it.
2013 GMC 3500HD Duramax
2016 Cedar Creek Silverback 29IK
curteric is offline   Reply With Quote
Old 12-08-2021, 10:02 AM   #10
halla's Avatar
x2, added cold water filter under the sink, no cutting and works great. Bought it on Amazon.
2018 Dynamax Force HD BH---Just Rite-2
halla is offline   Reply With Quote
Old 12-08-2021, 10:49 AM   #11
Commercial Member
I just drink the stagnant contaminated water. I am now immune to everything!
Old 12-08-2021, 08:00 PM   #12
FOURWHL's Avatar
This explains a lot tbh...
Old 12-11-2021, 06:34 PM   #13
Maybe, but I have not taken delivery yet.......Can you do pushups?
Thorne Parker, Esq., CDR, USN-Ret. (Push up Parker at Aviation Officer Candidate School, AKA the movie "An Officer And A Gentleman".
2022 DynaQuest XL on order via MHSRV 3400KD CabOver, WD, Lithium Batteries and some more to be announced later
twp5253 is offline   Reply With Quote
Old 12-11-2021, 06:36 PM   #14
So, hot and cold lines are visible under the sink? I hate to drill through my new counter top. I am having a hard time mounting a camera to the outside of my GarageMahal. I have issues. Picture would be awesome! TIA
Old 12-16-2021, 08:21 PM   #15
Originally Posted by Webefine View Post
I just recently cut out my solid surface kitchen sink and installed a single bowl stainless. I used standard drill bits and jig saw blades and had no problems cutting or drilling the solid surface material. A hole saw should work fine.Attachment 266495
I have some jig saw blades that cut on the down stroke. Much less chance of ragged edges or chips on top. Most big box store have them.
https://www.lowes.com/pd/LENOX-5-Pac...ade/1003189066
Western PA
KZ 270THLE
2015 Silverado Z71
gw1800 is offline   Reply With Quote
faucet, water
