Old 02-03-2024, 09:17 AM   #1
NXR
NXR's Avatar
Adding safety chains to a propane tank to help keep it from falling to the road
Remember this thread from October 2023? https://www.forestriverforums.com/fo...er-270546.html
A 2023 Europa owner found one end of their propane tank had fallen down and was almost hitting the ground due to missing nuts on the mounting bolts.
A similar failure mode has affected some later model Georgetowns when the front mounting bracket welds failed or the rear mounting bracket partially cracked.
Since both model tanks are lifted up from underneath and bolted to the bottom of the 90-degree mounting brackets I thought Dynamax owners might be interested in what I did to help secure our Georgetown ASME tank.
For less than $40 in parts and maybe two hours, including the driving time to and from the hardware store, I added safety chains to each "corner" of the tank. Yes, the attached PDF has lots of pictures.
Note that the Georgetown, at least ours, uses 7/16" bolts that are 2 1/2" long so that's what I specified in the attached PDF. If you decide to do something similar to your Dynamax you should confirm the size and length of the existing mounting bolts. Or perhaps Brian could find out.
Hope this helps someone out.
Ray
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
Old 02-04-2024, 09:17 AM   #2
Steve & Linda M.
MevetS's Avatar
Nice job on the write up.
Thanks!
Started in the "Pumpkin" '79 Burnt Orange Dodge "Street Van" ... NW cruise, Canadian Rockies, Round trip to Alaska. Then' 94 Tioga Montara, '06 Jayco Jay Flight 5th Wheel. Workmanship decline started : '15 Thor Siesta & '17 Tiffin Breeze.
Another RV learning experience with our 2022 34KD Force.
2019 Jeep KL (Cherokee) TOAD
MevetS is offline   Reply With Quote
Old 02-04-2024, 12:59 PM   #3
Keep safety in the front of your mind all the time.
I like the screw on clamps that hold down propance tanks. If there is any question about them coming loose, by all means add a safety chain.
The item that makes me nervous is solar panels on RV roofs. They need tethers in case the attachments fail. A solar panel coming at your windshield is really dangerous.
ppine is offline   Reply With Quote
propane, safety, tank
