Old 08-04-2020, 04:03 PM   #1
Adding Solar to a Force
Our 2016 Force has no solar and as far as I can tell no pre-wiring for solar. In summary, what would be involved with adding Solar? I know you need solar panels but my question has more to do with inverters, charging system, switching mechanisms, etc. Is it even feasible? Thanks for any help it's appreciated.
DQskier is offline   Reply With Quote
Old 08-04-2020, 07:20 PM   #2
I found 8 gauge wires behind the control panel. They go underneath the rv towards the batteries. I think there are two more near the top of the electronics in the pillar behind the drivers seat. I have not added solar yet. I'll try to find a pic.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 08-04-2020, 07:31 PM   #3
FOURWHL's Avatar
The solar controller is separate from your inverter and charger. They can work in unison.
Need panels, wire, solar controller and ideally a good battery monitor.
Check out amsolar.com lots of good info and very helpful people if you want to talk to somebody.
I built frames to mount 600w on my 2016 DX3
ID:	235719Click image for larger version
2016 Dynamax DX3 - Big Blue
https://fourwhl.com - Traveling the country in our DX3 for the next year
FOURWHL is offline   Reply With Quote
Old 08-04-2020, 11:41 PM   #4
Thanks for the input. Great looking rack, thanks for the idea and pictures. Also thanks for the advice on where to start looking for the correct wires. All very helpful, thanks!!
Old 08-05-2020, 04:50 PM   #5
Webefine's Avatar
I did a 400 watt system from Renogy.
I didnít want anymore holes in my roof so I went with glue down feet. 2 years and 10,000 miles and everything still looks good and working fine.Click image for larger version
Webefine is offline   Reply With Quote
Old 08-05-2020, 07:05 PM   #6
Thanks for that input Webefine, I will check it out.
Old 08-06-2020, 04:04 PM   #7
Attachment 235719Attachment 235720
I'd like to see a picture of your charge controller and assorted fuses/breakers.
Old 08-06-2020, 04:15 PM   #8
FOURWHL's Avatar
Used inline fuses at each panel. They're wired in parallel and combine at a box on the roof then 2 AWG to the controller. Couple more pics attached
ID:	235903Click image for larger version
Old 08-06-2020, 10:13 PM   #9
Nice work man! And sweet rack 4 wheel!
ójohn
johndjmix is offline   Reply With Quote
Old 08-07-2020, 08:48 AM   #10
Worm43's Avatar
Where did you penetrate your roof for the wiring?
2017 Dynaquest 37XL RB "Thor"
2016 Jeep Wrangler JKU
Worm43 is offline   Reply With Quote
Old 08-07-2020, 12:41 PM   #11
FOURWHL's Avatar
Right next to where the coax goes through the front cap. On the DX3 without cab over its under the false cap thingy. On the cab over I think it goes into the back of the cap. Click image for larger version
solar
