Old 10-12-2017, 08:43 AM   #1
Air Ride Seats
Brian, I want to change the driver and passenger seats in my 2017 Force to air ride. Can you give me the manufacturer and model of the seats that are used in the Force HD. Thank You
RITAOB is offline   Reply With Quote
Old 10-12-2017, 09:23 AM   #2
Commercial Member
zgipson's Avatar
I'm no Brian but I'll try to help when I can. He may be me to the punch before I'm done with this post! The swivel pedestals we use are made by Atwood and the Seats themselves are from Lexington.
RV | Lexington Seating
File Type: pdf Swivel Seat - ATWOOD IOM OPERATION BOOKLET4pg.pdf (238.0 KB, 90 views)
PLEASE do not send questions via Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
zgipson is offline   Reply With Quote
Old 10-12-2017, 09:31 AM   #3
halla's Avatar
I had added air ride seats to our 2016 Force, make sure you have them add a 12v compressor to each seat. If not you have to have someone tap into the air lines, which made me nervous. There is already a 12v set of wires for each seat now, it controls the adjustment.
Good luck and enjoy, the air ride seats made a huge difference.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
halla is offline   Reply With Quote
Old 10-12-2017, 10:46 AM   #4
Halla, Did you use the seats that Dynamax uses, or did you use an outside source ? Thank You
Old 10-12-2017, 11:56 AM   #5
Commercial Member
Tsk tsk, you did not give him the air ride section young grasshopper.
We buy them Freightliner on the chassis already. Best bet is to source parts through them.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 10-13-2017, 09:14 PM   #6
halla's Avatar
I used aftermarket ones, didnt have a contact for lexington at the time
Old 10-18-2017, 05:45 PM   #7
shultz01's Avatar
I wonder if it’s possible to have armrests added to the other side of the seats? It doesn’t appear clearance would be an issue.
Andy & Debbie Shultz
Harrisburg, PA
2021 Dynaquest XL 3801TS
shultz01 is offline   Reply With Quote
Old 10-18-2017, 06:41 PM   #8
Coolbaldguy's Avatar
I am interested in this too. But I have an 06' Dynaquest 320 that is using Bostrom seats....I think... Also the upholstery was custom for Dynamx because the DYNAQUEST logo is stitched into the head rest.
Coolbaldguy is offline   Reply With Quote
Old 10-18-2017, 07:02 PM   #9
halla's Avatar
I use a thing called arm saver on the door, helps without the other arm rest
Old 10-18-2017, 07:06 PM   #10
Thanks halla I will look that up. I do like the idea of having 2 armrests at the same height to keep me from sitting crooked. I am also looking into adding a grab handle above the window to give myself another option for left arm position.
