Old 05-15-2022, 12:22 PM   #1
Air Valve Ride Height
Does anyone have a part number for this valve? It's leaking, looks like the drivers side was already replaced at some point.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 05-15-2022, 06:26 PM   #2
KRedburn's Avatar
not at shop but
are you sure the valve is leaking and not just the air connects.
Try pushing in on the hoses and see if leak stops.
On mine the air bleeds off overnight which is fairly normal. You will also hear bleed off while you are setting the stabilizer feet. In most cases it is suggested that you dump air (if you have that on yours) before leveling.
If you are hearing a constant bleed (hiss) then you may have a bad hose connection or bad valve. The valves range from around 80$ to upwards of 170$ and are commonally available at NAPA or truck stores.
I'll look up number tomorrow on Freightliner parts.
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
KRedburn is offline   Reply With Quote
Old 05-16-2022, 07:48 AM   #3
If I wiggle the arm I can get it to leak where the nut on the rod and valve body meet.
Old 05-18-2022, 02:45 PM   #4
KRedburn's Avatar
Well, after getting my access straightened out I got the part number
16-14318-004 level control valve
available on ebay
https://www.ebay.com/itm/282865575781
Old 05-18-2022, 05:17 PM   #5
Thank you, I just ordered the part.
valve
