Anderson Valve Leaking????
I have a small about of water laying between the Anderson valve wall & the floor in the utility compartment. This is a FW model.
Anyone else ever experience this? It just appeared today & I was just curious, before I tear apart that area & try to diagnose the problem. Getting water into the RV, to all the fixtures, is not an issue when the valve is set on city or dry camping. Water pressure is also good.
The amount of water leaking out is minimal, but nevertheless - it needs to get fixed.
would it be easier to remove the entire outside panel (which includes the outdoor faucet) or just the inner part of the Anderson valve? I never had to disassemble this - so I was just curious
Any help would be appreciate. thanks
2019 Isata 3 FW
