03-20-2022, 09:16 AM
Antenna Booster Lost power
Had a thunderstorm last night in New Tripoli, PA. The antenna booster lost power. Checking the fuse is okay. No 12V DC at the yellow and white wires on the backside of the switch. Anyone know where these wires lead to/get their power?
Dave & Nancy
Western MA
2017 XL 37RB
03-20-2022, 09:20 AM
12v fuse in the load center?
TT - 2021 Rockwood 2608BS
TV - 2020 F-250 XLT 4WD SRW 6.2L gas
03-20-2022, 05:34 PM
The 12V fuse (F15), located in the Precision Plex control center below the countertop stove, was okay.
Looking for the yellow and white wires in the first compartment on the drivers side ( where the inverter lives), I saw a grouping of fuses. Would be great to have a legend for those fuses to know what they serve, Anyway, I pulled every one ( as opposed to checking them with a multi meter) abd checked them visually and all were okay.
When I checked the booster switch, I found it was energized and now all is well. So although I don't know the root cause of the issue, it is fixed. Perhaps some one may have a legend for these fuses to confirm there is a relation to the antenna booster?
Dave & Nancy
Western MA
2017 XL 37RB
03-20-2022, 06:06 PM
Perhaps turning on all the devices, pull the fuse(s) and note what each one powers. That's what I would do anyways...
2022 Cherokee Wolf Pup 18TO
2022 Dodge Ram 2500 6.4l Bighorn
03-20-2022, 06:20 PM
I didn't count them but if memory serves, there's 3 rows of 6 so 18 anyways. I think a better use of time is to get a legend. Could be quite a time suck.
Dave & Nancy
Western MA
2017 XL 37RB
03-20-2022, 06:50 PM
Commercial Member
If it is the precision plex system, when you cycle through the menu at the fuse panel, if tells you what each one is.
03-20-2022, 06:54 PM
Brian, thanks for your input, that is what I checked first-fuse F15 was okay. It was fixed by removing the fuses on the panel in the first compartment where the inverter is located. Do you have a legend for that panel?
Dave & Nancy
Western MA
2017 XL 37RB
03-21-2022, 07:19 AM
Commercial Member
There has been one posted here several times, in multiple threads. I am headed into a meeting, but will try and look after.
Maybe search "relay fuse layout"?
03-21-2022, 07:31 AM
That would be appreciated especially since the antenna booster does not work now. Thank you Brian.
Dave & Nancy
Western MA
2017 XL 37RB
03-21-2022, 08:15 AM
Commercial Member
03-21-2022, 11:46 PM
Sound like maybe a little mild corrosion on the fuse. Cured by pulling it and putting it back.
Bet you are in a wet climate??
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
