Possible Approach
I've been thinking about installing a manual "T" valve at the outlet from the macerator. The stem of the T would be attached to the outlet, one side of the T would have the current macerator hose, the other side of the T would have a new heavy-duty, flexible line. When draining the black tank, I would select the macerator hose, pull the handle for the black and turn on the macerator (essentially what I am doing now). When draining the gray tank, I would turn the valve to select the new hose and pull the handle on the gray, letting gravity do its thing. Another plus with this setup would be the ability to leave the gray valve open and not have to drain the gray every day. Thoughts on this approach?
