Old 09-03-2024, 06:41 PM   #1
Awnings that won't rip at ends!
Not a Dynamax issue, from what I see ALL awnings eventually rip on the ends where they connect to the coach. Im looking for some stronger awning material. I don't care what it costs, I just want something military grade that will last.
I still consider having an awning material made that has an embedded 3/32 aircraft cable on the ends, that would prevent the tearing issue.
--John
johndjmix is offline   Reply With Quote
Old 09-03-2024, 07:27 PM   #2
Sitting in the sun rolled up will damage it. Fabricate something with vinyl rain gutter or this
https://www.amazon.com/Awning-Protec...s%2C175&sr=8-9
Capacitor is online now   Reply With Quote
Old 09-03-2024, 08:02 PM   #3
My awning did the same, ripped on the ends. I put Gorilla RV awning tape on it however the damage is done as it now sags. It did not peel or anything like that.
2017 Wolfpack 315 Pack 12 5th wheel Toy Hauler
2013 F250 6.7 Diesel Dually 4x4
Odyknuck is offline   Reply With Quote
Old 09-03-2024, 08:06 PM   #4
malmz's Avatar
ToughTopAwnings makes stronger fabric. You measure, they make and ship it, you install it. Or they have dealers to do it all. I had them on my Discovery.
malmz is offline   Reply With Quote
Old 09-03-2024, 08:55 PM   #5
2012 Solera
Several years ago I saw the metal awning covers being offered. Shading the awning while rolled up seemed like a very good idea.
I chose to run 8 inch Eternabond along the inside edge of both my slide topper and my awning. Pretty thoroughly covers the top and outside edge of the awning and topper rolls. So far - several years later - my topper and awning have held up perfectly.
FYI, Jim
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 09-03-2024, 09:16 PM   #6
Good info, thanks. I considered using Eternabond however Being its designed for a solid application, I refrained.
Old 09-04-2024, 04:49 PM   #7
Sealing the edges...
The active element of Eternabond is a really sticky, flexible adhesive caulk. It's thick enough that it stays sticky forever--and develops a visible coat of dirt and crud. In visible, fixed (non-flexing) applications, their literature advises you to run a bead of a caulk that dries (e.g., acrylic), for aesthetic reasons. That won't work as well on an awning.
Larry
Larry-NC is offline   Reply With Quote
Old 09-05-2024, 05:24 AM   #8
I replaced my awning fabric with this place in Florida
https://stonevos.com/
2017 River Stone Legacy 38mb
2001 Kenworth T2000
2016 Smart for Two on deck
dblr is offline   Reply With Quote
awning
