Originally Posted by rskeans
I wish that I could think of all of the combinations of tests at one time. I just tried the LED test, this time with the ignition on. I now have the two green leds as you suggested. Therefore it must be all OK.
Now the acid test will be to just park it in storage, plugged in, and see if the chassis battery holds its charge. The difference would be the new solenoid.
Stay Tuned!!!
Yes, so all that you just described is normal.
Did you read the bird "theory of operation" second paragraph.
It seems that your chassis batteries could be bad.
What is the voltage of the chassis batteries? if they are below 13.1 the relay
or solenoid in the picture that you have will open and there will be no charging of the chassis batteries.
You may want to pull them and get them load checked. Maybe you have done all of that, if not look there next.
